check the leads in the back are in the right position -most of these are colour coded -white to white red to red yellow to yellow -otherwise you may have to use a hdmi cable or you may just not have the tv unit in the right settings -read your manual if you have one -these can be quite confusing so just play about with it but try and remember what youve done -otherwise see if unit has a factory preset switch you can push and it goes back to how it was set at factory...
What is the make and model of the TV? With this you can easily download the manual online. Simply type make and model as well as user manual on google and you will get the manual downloaded.When the TV displays no signal then it is because there is some inconsistencies in the cable which is supposed to supply pictures to the TV. Check that the cables are properly fixed and the unit is on the right channel for the No signal problem. Hope this solution has been helpful?
Take off grill, take off panel, on left side on front of circuits you will see a small switch. Push button. Remember to save data after adjustments are done via TV's remote.
It ended up being the Verizon Fios box. We recycled it and the picture stopped rolling. Thank you for being here to help. If I have any future questions, I'll definitely use your site.
hi sir,
it is quiet clear you have a dried up capaciters in the power supply board and the capacitors of the feeding volts 115v 12v 24v
please refer to qualified person to replace them all and evrey thing will come to regular state
please don't forget to rate and remember i am here just for help
thx
