HOW DO I DO A SYSTEM RECOVERY ON THIS UNIT. IT DIDNT COME WITH A DISC AND IT DOESNT HAVE IT ON THE COMPUTOR, IT ONLY HAS A SYSTEM RESTORE
Acer Aspire 4315 Restore To Factory Settings see if link will help you out.
SOURCE: Compaq Presario m200 Laptop system recovery
i have a problem i want to restore my compaq m2000 to factory standard but i cant because my disk drive does not show up in my computer and when i try to use a disk it doesnt work
SOURCE: I need to restore my laptop to the factory
If you put the first disk in it will auto start and prompt you through the process.
SOURCE: I'm trying to wipe my hard drive with Fedora 12
Jeff what you have to do is this dont disturb yourself just go straight off the system then later on it and press your key F11 down at a time simultaneously then it will bring the system recovering factory settings for you and follow the instructions then you are through is just that all you have on the system will be gone but you will have your system back alive the way it was manufacture to work BYE THANKS
SOURCE: i have no system recovery disc but i want to factory setting
Providing the laptop was built after 2005 then there should be a recovery partition on the laptop.
Turn the laptop on and repeatedly press the F10 key, this should get you into the recovery partition and allow you to factory restore the laptop.
Regards.
