Download MiniTool Partition Wizard Bootable CD 7.1 from
Here.
Or Download Directly by Clicking
hereThis CD allows you to boot computer directly into MiniTool Partition Wizard to manage partitions without any limitations. You can rebuild MBR, Partition Recovery, Move/Resize Partition, Merge Partition, Change Cluster Size, Copy Partition, Create Partition, Delete Partition, Format Partition, Convert File System, Hide/Unhide Partition, Explore Partition and much more.
Burn ISO file onto a CD using any CD/DVD Burner software.
Set the CD-Drive to 1st boot device in BIOS.
Insert it into drive and reboot the system.
You will get Partition Wizard Boot Disc Menu.
What to expect from this bootable CD
Step 1: Choose boot disk
Step 2: Choose screen resolution
Step 3: Manage your partition
How Delete All Partitions?-
There are two ways to start this function:
1) Click on Disk in the top menu, click Delete All Partitions from the drop down menu.
2) Click Delete All Partition under Disk Operations in the Action Panel.
Delete All Partitions will delete all the partitions in the present chosen disks.
Note: May cause Windows to not start properly when used on
partitions containing the boot partition or system partition.
For more information check the website
LinkHope this will be useful for you.
Best Regards
Nandu
Are you under warranty? If yes, they have excellent on line support help.
