Hello Kamaleddin_e , this no scan option issue occurs when you try to scan from the printer. It usually means , you need to set the destination file type, which is currently not populated (destination file type is the file type to which you want to save the file which you are scanning. If the device finds the list is empty (list of associated file types) , then it displays the "No scan options" error on the printer.
You can populate the destination list by following these steps.
1. Open the HP Solution Center
2. Navigate to Scan Picture Settings (or Scan Settings)
3. Select "Scan to Button" tab
4. Select destination list tab. (Note: If the appropriate programs are already listed as scan destinations,
discontinue this procedure. The software must be reinstalled.)
5. There will be 2 colums visible, the left column is the scan destination list on the computer and the right one is for the scan destination list on the printer.
Click each program to include on the
Scan To
list. Click the
Add
arrow. The program listing moves from the left side of the screen to the right. Click OK.
6. Now try scanning again from the front panel.
(Note: Please make sure that the HP Digital Imaging Monitor is also running as it is required for the HP software to function properly. You can find it as an icon in the system tray. If there is no icon, then you can run the application by navigating to C:\Program Files\HP\Digital Imaging\Bin\HPQTRA08.exe (Assuming C: as your system drive)
Mostly, the issue will be resolved at this stage or else you need to uninstall the software and reinstall it again.
all the best.
thx
SOURCE: HP 3310 All in One Printer with Scanner
How to fix HP Photosmart 3310 All-in-Onein scanning?
