Default Password
If you have changed the default password
and have forgotten it, you will need to reset the NETGEAR device to
factory default settings in order to use the default username and
password.Please note: restoring a device to its factory default
settings will erase any changes you have saved to the device.
If you have changed the default password and have forgotten the
password, you may need to reset the NETGEAR device to factory default
settings.When a NETGEAR device resets, it goes back to the state when it was new - all information that was entered by hand is lost!
Examples include critical things you need to get online, such as ISP
username, ISP password, IP addresses, wireless security keys, and ports
and services that were opened. It all needs to be re-entered.
So, have your ISP information before resetting the router.Naturally, if you moved to a new city, or if you bought a used
router, the old information in the router may not be of use to you.
Contact your ISP if you can't connect any computer directly to the
Internet. Then, if there is a connection problem when the router is
added, see No Internet Access Through the Router Reset for most routers with a reset button on the rear panelWrite down configuration information such as IP addresses, security
keys, opened ports and services, etc., that you modified. (The default
username is admin and the password is either password or 1234. Try these before resetting the router.)
For DGN2000 / DG834Gv5 Routers
To restore the factory default configuration settings when you do not
know the login password or IP address, press both the Wireless button
and WPS button on the side of the modem router for 5 seconds.
For FR314, FR318, and FV318
These routers require reloading the firmware in order to recover from
a lost password. Download the most recent firmware from NETGEAR's Web
site before proceeding. Follow the instructions in the manual.
For routers with a 9-pin manager port on the rear panel: RT314, RT311, RM356, RT328, RT338, RH340, and RH348
See Updating Router Firmware That Uses a Manager Port.
This applies to:
All NETGEAR devices
Note This is not my copyright sorry -This answer is copied from some where
