Anonymous Posted on Nov 17, 2011
MX6050D Subwoofer Issues
All other speakers are working but the subwoofer does not seem to be gettin power from the main system.
Wale Sarumi KomputerSolution
Level 3:
  • Master 6,993 Answers
  • Posted on Nov 17, 2011
Master
Level 3:
Answers
6993
Questions
Helped
1701420
Points
1261
Hello, welcome to Fixya!
Fault is either from the main system or the sub-woofer itself.
You need to test both unit in order to detect which of the two is giving the fault, so that you can concentrate on the faulty unit.
Test the woofer with a AA battery or any other battery. Put your ears close to the woofer and observe if you will hear any sound. If the woofer makes sound, then it means the woofer is working, but if it doesn't make sound, then it means the woofer is defective. Or you can disconnect one of the working speakers and connect the woofer to that part. If there is no sound, then obviously, the woofer is defective.
If the woofer seem to be working, then the unit needs to be tested also.
Connect one of the working speakers to the sub-woofer's section of the main unit. If the speaker doesn't bring out sound, check the system's menu settings, check the volume and make sure the sub-woofer volume is raised to the highest level and not on mute. ( Note that most Theater systems has separate volumes for each speakers). If the volume is raised to the highest level and there is still not sound from the woofer part, then it means the woofer channel has burnt. It could be a fuse or a defective channel. At this point, I think you need help from a repairman.
I hope the above is clear.
Regards.
  • Anonymous Nov 17, 2011
    Thank you for your help! I will give this a try and see what happens! Thanks again!
How do I hook up the sub woofer to my home stereo system
You don't say what make or type either of the appliances are, so I can only answer in general terms.
First look at the back of your stereo system and see if there is a dedicated subwoofer output. If there is you should be able to find the correct lead between the two units by looking at both the connections. If the subwoofer is a powered one. IE with a mains plug on it, you have to plug it into the mains before it will work at all. The connection points also then need to be hooked up to the amp. If it's not a powered subwoofer then your main left and right channels speaker wires need to be split into using the subwoofer terminals provided. Another set of terminals on the sub, then lead to the main speakers.
Lastly if it has a dedicated subwoofer output, then the amp might have a setting that turns this on or off. So you might need to switch it on.
How do I hook up a powered subwoofer to a pioneer sx-316?
Many subwoofers accept both line level (RCA jacks) and amplified inputs (+ and - speaker terminals). The Pioneer SX-316 does not offer line level output, only amplified outputs via the PURPLE + and - speaker terminals. This means that in order to use any subwoofer with an SX-316, the sub woofer will need to accept a + and - speaker wire connections for input Your manual speaker connections are on page 11 of the manual which can be found here: http://www.manualslib.com/manual/260358/Pioneer-Sx-316-S.html#manual
Starting at the rear of the SX-316; run a speaker wire from the PURPLE + and - terminal (SUBWOOFER) to the + and - speaker input terminals on the subwoofer. See your subwoofer manual or experiment (at your own risk) with connecting the speaker wire from the SX-316 to the subwoofer's + and - LEFT only, RIGHT only or BOTH left and right speaker inputs. Do not connect wires from the SX-316 to the speaker OUTPUT terminals of your subwoofer.
Finally, adjust any variable low pass filter knob or setting on the subwoofer to the lowest frequency that your main speakers are capable of producing. If you're not sure what that value is, try setting the subwoofer to 100Hz and judge how it blends with the main speakers. If it seems a little too bass heavy and thick then reduce the setting to 80Hz. On the other hand, if the sound seems to be slightly thin and lacking weight, try increasing the setting to 120Hz. By careful listening and a bit of patience you will be able to get the sound to seem balanced and well blended.
Subwoofer not working
The subwoofer is normally the main power supply for the other speakers. When setting up the system, there is a set up guide which allows you to control the power supplied to each speaker. You may have inadvertently set the subwoofer to have 0 output.
How to connect subwoofer
This manual discusses it somewhat.
http://service.us.panasonic.com/OPERMANPDF/SAAX730.PDF
Basically, feed the self-powered (active) subwoofer from the Subwoofer Out. There does not seem to be a way to adjust the subwoofer output to match the rest of the speakers because the sub out is muted during the adjustment procedure.
Another way would be to refer to page 15. The note at the bottom right suggests your subwoofer might accept full range speaker level inputs. Refer to the manual for your sub. I believe they mis-printed it and meant "active" subwoofer, as simply wiring a passive (unpowered) sub across the front speaker outputs might cause some amplifier overload issues and you would have no way of balancing it anyway.
Subwoofer turns on and is hooked up, but no sound.
The signal don't seems to be present to the sub input.
Try change the wire betwen the audio system and the subwoofer.
Spider Guy
Power issues: will not turn off or function
Unplug all of the speakers and power on.Its possible that one of the speakers is causing the protection circuit to activate.If powered on and subwoofer works start reconnecting one speaker at a time( after powered off) and retest each time.One Speaker may be bad.Its also possible the output ic is failing under a speaker load.There are no fuses related to this issue.If its not a speaker problem then the subwoofer will need to be serviced.
2answers
Subwoofer connection
if this is ao powered sub, that plugs into the wall, there should be no problems, if it is powered solely by the reciever it may work fine but be sure you dont exceed amperage on the subwoofer.
2helpful
3answers
Cerwin vega ht-10d subwoofer won't work in yamaha reciever
Well, as I know, your Cerwin Vega subwoofer is designed for use with stereo systems. Therefore, it has only 2 channels for input, and 2 channels for output as well. However, you can try this out; the first thing I suggest is that you hook up your main front channels through the subwoofer. All you have to do is to connect the subwoofer input to the front channel output on the amp, then hook up your front speakers to the satellite output on the subwoofer. As long as you make sure that system is working on 8 ohms, I believe this can activate the subwoofer.
2answers
Subwoofer
Most AV receivers do not have a built in amplifier block to drive a subwoofer, and merely provide the subwoofer output channel at line voltage. Thus, a powered subwoofer is required. Does the subwoofer require mains power? From your description, I'm guessing it doesn't. If not, it does not have a buit in amplifier, you will need to purchase a monoblock amplifier, which is just a mono amplifier with a volume control, no tone controls or anything else. Make sure that the amplifier power rating is as close as possible to the subwoofer power rating, as it is quite possible to blow a speaker by using an amplifier whose power output is too low, by overdriving the amplifier , and putting DC through the voice coil when the amplifier clips. If it does require mains power, it will have an amplifier built in, but does not have line level inputs.
 Grubhead
Grubhead
SmartAviator
SmartAviator
