I have purchased a new modem (DM111P) i can access the internet through the modem but when i plug the ethernet cable into the belkin wireless router the computer says that the cable is unplug but the wireless connection is pickup by the computer but no internet access
Since it says network cable unplugged on the computer when wired to the router, you need to check these first:
â Make sure that the Ethernet cable is connected from the modem to the router’s Internet (WAN) port and the computer to the numbered port of the router. The computer should used to be connecting to the Ethernet port of the modem, if not; you should contact your ISP first.
â Make sure that the Ethernet adapter/LAN card on your computer is working properly. You can check that on the device manager of your computer.
â If those are all working fine that would mean the router is not yet configured for Internet access or we can say that the settings for the provider are not synchronized with the router.
To configure the router, you can do these general steps:
1. Connect the computer to the numbered port of the router and the modem to the router’s Internet (WAN) port.
2. Turn off the computer, router and modem.
3. Turn on the modem first, wait for the lights to stabilize then turn on the router. As soon as the lights are stabilized, you can turn on the computer and check for internet connection.
However, if the Internet connection still does not work. That means there are additional settings needed to be done. You can message me about the name of your ISP and I will provide you the specific steps you need.
hey m using mtnl broadband and have a belkin router....
pls help me abt how to connect the router....
I got a new Adsl2+ NETGear DM111 working fine on the cable but the Belkin can't connect to the internet through it after all the set up is ready. Is there a firewall issue? please help
isp is post office.. everythin works fine, try to connect router between comp and post office modem and cant get internet connection either wired or wireless. was on phone to tech support for over an hour and he kept blaming my internet connect which is fine until i connect router.. we tried a few things more than once i might add, nothin he suggested seemed to work, in a nutshell my compter and laptop both connect to router. but my router wont connect to the post office modem.. which i know works if i byepass router
