For simple setup instructions, go here:
https://www.att.com/esupport/article.html#!/smb-internet/KM1189747
For more detailed setup instructions, go here:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&cad=rja&uact=8&ved=0ahUKEwiD9oOZg5DYAhXmy4MKHaaMA2oQFghAMAQ&url=http%3A%2F%2Fwww.finestplanet.com%2Fdownloads%2FSS4100install.pdf&usg=AOvVaw3UU1BKiwxaBLxLLwlwyEnV
Actually, you will not find a driver on Siemens driver website because according to Siemens, the 4100 Ethernet model works with any Ethernet equipped PC, regardless of operating system.
Just ipconfig in command prompt and you will get the default gateway and you can actually get the config page to configure the same. Good luck.
SOURCE: speedstream 4100, can't download internet
make sure your its enabled in your bios
during the boot process you will see on your screeen to press acertain key to enter set up press and hold that key to enter set up
using arrow keys navigate to intergrated peripherals press enter look for SiS 10/00 press enter make sure ethernet its enabled
press f10 save to cmos
restrart your computer
if this fails to fix the problem
the driver for this modem should be on the motherboard disk or the disk provided by you ISP internet service supplier
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled or
you could click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow question exclamation mark or a red X you will need to update/reinstall the driver for the device if you computer came with a motherboard disk the driver could be on it
also
the drivers might be installed for this device
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
http://download.cnet.com/intel-r-82562v-10/3000-2110_4-99324.html
http://download.cnet.com/intel-r-82562v-10/3000-2110_4-99289.html
hope this helps you
