Yo! i will have to direct you to a link where you can download absolutely anything for your computer.please visit
www.filehippo.com
www.download.com
Http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2441148&rpn=PSLY1U&modelFilter=L450-EZ1543&selCategory=2756709&selFamily=1073768667
Choose the "Sound" driver.
I hope this helps and thanks for using Fixya!
*If this was helpful, please leave a great rating so others may benefit from this answer too! **
Follow this link Toshiba Support Driver Download, then select your operating system
SOURCE: audio driver for tos satellite a100
you should be able to get it from realtek.com.
you need the high def driver.
or you could download driver max and it will update all your drivers for free.
SOURCE: TOSHIBA Satellite L450 user's guide! Help me
Here you go... Good luck.
http://www.retrevo.com/support/Toshiba-L450-EZ1543-Laptops-manual/id/23577bh231/t/2/
-AD
SOURCE: audio driver for toshiba satellite pro M300/l310
Try this link for your drivers,there are a few here http://www.rapidhop.com/search.php?q=Toshiba+Satellite+M300+L310+Intel+Display+Driver+For+XP+www+getpcmemory+com+zip
SOURCE: Toshiba Satellite Pro L450 Touch
"Hi sara_sara_ab, let's see if we can fix this problem"
I. "To "Enable" the Pointer Device using the Touch-Pad, go to, Control Panel, click on the "Start Button." in the [Right] short-cutmenu, select to open the Control Panel. In the next window, choose the ("Mouse") applet, in the "Hardware and Sound" category; go to, "Device Settings" in the (Devices) block.
II. "Highlight"; the item you want to (enable) this being the Pointer Device." Click the (Enable) button, just below. Be sure to (Click) on the "Apply" button, and click OK. "III.You may need to "Update Drivers?" Click on "Hardware, click "Properties," click, on Driver." If the, Update Driver (block) is not "Grayed-out;" click "Update Driver," and click (OK), this will ensure that the application take effect.
Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware.
Hope this Fix it. "Please find the time to give a "Helpful Rating," and thanks for using Fix'Ya, paul70f9."
SOURCE: Toshiba Satellite Pro L450 wireless driver
www.filehippo.com
www.download.com
