SOURCE: We lost power today and know my oven doesn't work.
Jim, In reading your post I'm assuming the control panel is operational. According to the model number it is a slide in range. You need to remove the lower panel and the flame spreader in the oven and see if your ignitor is coming on. It will be attached to the rear of the burner tube. In order to open the gas valve it needs to draw at least 3 amps and a steady 3.4 to 3.6 amps during heating. If your handy you can test this with a clamp on ammeter. Ohming it out should show around 171K ohms. On this model this rectangular ignitor is not interchangable with the cylindrical generic ignitor, they draw different amperage and use different gas valves. This is not a hard job to do, just need to take your time and observe...Catriver..post back.
SOURCE: surface units working, oven is not. clock panel is blank.
Sounds like your going to have to replace the control board. Sometimes after a power failure there's a surge when the electric comes on and this can fry a control board.
SOURCE: GE Profile JGB97 Self Cleaning Oven Controls won't work
It sounds like the controls have been placed into a lockout mode. If your model is a JGBP79 do the following:
1) Press the BAKE and BROIL HI/LO pads at the same time for 3 seconds until the
display shows SF.
2) Press the SELF CLEAN pad. The display will show LOC OFF.
Now here is where the directions are kind of confusing, I will give it as they say it:
3) Press the SELF CLEAN pad again. The display will show LOC.
4) Press the START pad to activate the control lockout feature and leave
the control set in this special features mode.
Seems to me if its locked already, you would just do steps 1 and 2. And if you wish to lock it do steps 1 thru 4.
SOURCE: Jenn Air Oven Model # SVE47600B Error Code F7
I have a jenn air SVE47600F.It just started beeping and giving a code 7.None of the controls work when it brings the code up,but controls work fine when code is not there. We have to turn the breaker off to reset it.Sometimes when we have been gone all day we'll come home and the range will be beeping and flashing a code 7
SOURCE: GE Profile electric range: I'm getting an F0
Hi greengib,
The Failure code "F0" description is a stuck touchpad. Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Hope it helps.
Thank you for using FixYa.
