Turn the unit OFF & unplug it. Remove the water collection bucket and set aside. At the top of the bucket holder, just behind the louvers you should see a plastic pull tab, which is part of the filter frame. If you have never removed the filter before, there may be a piece of plastic tape on the filter frame. It was put there for shipping. Remove and discard it. Pull straight down on the plastic tab and remove the filter. It can be cleaned by vacuuming it or if it's really dirty, wash it in with warm water and mild dish washing liquid. Rinse thoroughly, shake off access water and allow to completely dry, before reinstalling it. Never operate the unit without the filter in place, as doing so could cause damage to the unit. The filter should be removed and cleaned once every two weeks.
Hope this helped you and thanks for choosing FixYa.
Thank you for your post, Lee!
From the information you have provided you with like to take the caster wheels off in order to allow stability to your Frigidaire dehumidifier. We would not recommend removing the caster wheels. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
Hey friend, thank you for your post!
I understand that you would like to remove the cabinet within your Frigidaire dehumidifier. Typically, the cabinet is not accessible. If you need to access anything internally within your dehumidifier I would suggest seeking assistance from a professional. Best regards! -Matt
Hello Diane Weber, thank you for your inquiry!
I see that you have recently purchased a Frigidaire dehumidifier and the display is not working properly. When you returned the original appliance did they test it in store to see if it worked? Are you using any type of extension cord or surge protector on the appliance? With this additional information I can better assist you. -Matt
