Frigidaire FAD704DWD 70 Pint/Day Energy Star Dehumidifier w/ 16.3 Pint Tank Capacity, Up to 194 CFM, 115V, 2 Speeds, Antibacterial Mesh Filter, Auto Shut Off, Effortless Humidity Control, Full Tank Alert, Continuous Drain Option & Portable Design Logo
D
Diane Weber Posted on Aug 28, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Frigidaire dehumidifier brand new will not start.
Frigidaire dehumidifier fad704dwd is brand new. When I plug it in, the display lights for about 1 second, then goes black. On/Off doesn't work. I've tried 3 outlets. Each time it briefly lights then goes dark and cannot be turned on. I returned the first unit, now same thing with 2nd brand new unit. Suggestions?
  • Official Brand Answer 2,267 Answers
  • Posted on Sep 02, 2014
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1289994
Points
2557
Hello Diane Weber, thank you for your inquiry!
I see that you have recently purchased a Frigidaire dehumidifier and the display is not working properly. When you returned the original appliance did they test it in store to see if it worked? Are you using any type of extension cord or surge protector on the appliance? With this additional information I can better assist you. -Matt
5 Related Answers
Anonymous
  • 43501 Answers
  • Posted on Apr 30, 2010
SOURCE: dehumidifier shuts off
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Anonymous
  • 43501 Answers
  • Posted on May 05, 2010
SOURCE: Frigidaire 70-pint dehumidifier won't work after winter
No reset button on the compressor... but this tip may give you some clues as to what is or is not happening..
Dehumidifier is running but no water is in bucket
heatman101
Anonymous
  • 36 Answers
  • Posted on May 28, 2010
SOURCE: frigidaire dehumidifier compressor does not seem
Either you have some sort of leak and there is no freon pressure or..Your compressor wont turn on because of a swith or control isn't telling it to..Does the fan still blow?
Anonymous
  • 43501 Answers
  • Posted on Jul 13, 2010
SOURCE: Frigidaire 50 pint dehumidifier freezing up and
Dehumidifiers2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
Anonymous
  • 4736 Answers
  • Posted on Apr 28, 2011
SOURCE: My Frigidaire dehumidifier model FDL70S1has
All most all dehumidifiers have a defrost cycle to take care of this problem. However, yours is either not working or the air intake filter is clogged, which makes the unit strain to keep up. Turn the Master ON/OFF Switch to OFF and unplug the unit, before attempting to remove the filter. Allow the unit to thaw while it's unplugged. Once it's completely thawed, plug the unit back in, turn the Master ON/OFF Switch to ON and set your controls as you normally do. Within in an hour or two, you will know if this solved the problem. Also, keep in mind, dehumidifiers are designed only to work in temperatures above 41 degrees. If it's below that where you have the unit, that will cause it to freeze up.
With all that said, what you're seeing as the Error Code is in fact, AS (the 'S' looks a lot like a 5 on the LED screen) It indicates a Sensor Failure. In your case, it's more than likely the Defrost Cycle Sensor. The Owners Manual says "Contact your local Authorized Frigidaire Service Center, if this happens. I'm hoping that cleaning the filter (if needed) and allowing the unit to reset itself (while it's OFF & Unplugged) will solve the problem. But, it may only be a band aide fix.
Hope this helped you.
2helpful
2answers
I have a FDL70S1 Frigidaire 70 pint dehumidifier and need to clean the filter. I've lost my manual. So how I get at the filter? Thanks Glenn
First, I'm not a Frigidaire tech.
* Check your warranty. Call for service.
* Contact (note Live Chat link); https://www.frigidaire.com/Search-Results/?q=dehumidifier
*** The following is for information only ***
* Note that this filter is a "wash - Reuse" and is probably considered a "Part" and not a consumable.
* Filter (check if this will fit); https://www.amazon.com/Frigidaire-5304487154-Dehumidifier-Filter-Unit/dp/B00PU1V4M2/ref=sr_1_1?s=home-garden&ie=UTF8&qid=1531339454&sr=1-1&keywords=frigidaire+fad704dwd+filter&dpID=61e1c6OA6UL&preST=_SX300_QL70_&dpSrc=srch
* Review; https://www.youtube.com/watch?v=BbwIEU3zlG8
* Correcting "Bucket Full" Error; https://www.youtube.com/watch?v=UzGnUG3r8dU
* Review (includes using a hose drain); https://www.youtube.com/watch?v=aAKN--TgQRI
* If your missing this filter then contact the local Frigidare or Appliance store for a replacement.
* Final; check your warranty. The filter may be covered.
Aloha, ukeboy57
Is there a recall on Frigidaire dehumidifier model # FAD704DWD?
None that I can find. You should contact the manufacturer for the definitive answer.
Dehumidifier Thermistor
there is NOT...
By your model number...
I bounce off of a lot of other (subsequent models (I presume))...
But your model does NOT resolve to any serious parts
USA domestic suppliers... not even good drawings!!
I tried appliancepartspros, easyapplianceparts, repairclinic, partsselect & searspartsdirect.com
Got spanked pretty good... Looked at related circuit boards... but none had any significant detail to determine a THERMISTER
FROM... Do not match
Time to get the ACTUAL NUMBERS OFF OF your thermistor...
and go to electronic houses... eBay, grainger... even RadioShack
In my humbled opinion...
FAD504DUD ENG10 12 FAD704DWD Dehumidifier Display Circuit Board Frigidaire...
Water Filters Lawn Garden Appliance Parts
PartSelect Appliance Parts and Repair Help
Find Your Appliance Parts
2helpful
2answers
Why does compressor continue running, even with dehumidifier turned off?
So I just had this happen with my Frigidaire fad704dwd dehumidifier. I went to basement and heard it running and sounded off. The compressor was running fan was off which is bad and humidity said 30. I then pushed the off button and it stayed running. I was able to fix it. To make long story short it was a bad ground. I took the plastic back, sides, and front off. There was a green ground (main ground) and Green/yellow ground (fan ground) on the front coil with a bunch of rust. Removed the grounds connected them both together and cleaned the surface area and used a new stainless screw nut and screw to remount the wires to evaporator coil. Everything started working fine after that and I put it back together. Good Luck
How do I remove the cabinet from a frigidaire dehumidifer?
Hey friend, thank you for your post!
I understand that you would like to remove the cabinet within your Frigidaire dehumidifier. Typically, the cabinet is not accessible. If you need to access anything internally within your dehumidifier I would suggest seeking assistance from a professional. Best regards! -Matt
Why does Frigidaire dehumidifier send water outside bucket?
Good Afternoon Jean,
I understand that your Frigidaire dehumidifier, model# FAD704DWD, is putting the water that it collects out onto the floor as oppose to the bucket. I suggest contacting the manufacturer for more information. They should be able to point you in the right direction for assistance. Hope this is helpful.
-Best Regards-
WP
Why does Frigidaire dehumidifier FAD704DWD send water outside unit?
Good Afternoon Friend,
-Best Regards-
WP
Just bought a brand new Frigidaire 50 pint dehumidifier. As waited 2 hours before plugging it up and when I did I got a ES error, the unit runs but the display flashes between "CO" and...
Read the instruction manual thoroughly and ensure you did everything exactly. If it still doesn't work it is faulty and should be returned.
Top Frigidaire Dehumidifiers Experts
john h
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
