20 Most Recent Frigidaire FAD704DWD 70 Pint/Day Energy Star Dehumidifier w/ 16.3 Pint Tank Capacity, Up to 194 CFM, 115V, 2 Speeds, Antibacterial Mesh Filter, Auto Shut Off, Effortless Humidity Control, Full Tank Alert, Continuous Drain Option & Portable Design Questions & Answers
Hello William, thank you for your post!
I understand that you would like to have a dehumidifier that restarts after a power outage. I have reviewed the available models for Frigidaire and show that feature is not available. You may want to speak with additional manufacturers for that feature. I hope this information is helpful to you. -Matt
Frigidaire... | Answered on Sep 28, 2017
Thank you for your post, Lee!
From the information you have provided you with like to take the caster wheels off in order to allow stability to your Frigidaire dehumidifier. We would not recommend removing the caster wheels. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
Frigidaire... | Answered on Aug 14, 2015
Thank you for your inquiry, Lisa Cooper!
I understand that the power light on your Frigidaire dehumidifier is not showing you the power light is on. It sounds like you could have an issue with your control panel. If your dehumidifier is running it could be that the light has failed. If you have a current warranty I would reach out to your manufacturer to see if they have a resolution for such an issue. Hopefully this helps. -Matt
Frigidaire... | Answered on Nov 18, 2014
Hello Diane Weber, thank you for your inquiry!
I see that you have recently purchased a Frigidaire dehumidifier and the display is not working properly. When you returned the original appliance did they test it in store to see if it worked? Are you using any type of extension cord or surge protector on the appliance? With this additional information I can better assist you. -Matt
Frigidaire... | Answered on Sep 02, 2014
Good Afternoon Jean,
I understand that your Frigidaire dehumidifier, model# FAD704DWD, is putting the water that it collects out onto the floor as oppose to the bucket. I suggest contacting the manufacturer for more information. They should be able to point you in the right direction for assistance. Hope this is helpful.
-Best Regards-
WP
Frigidaire... | Answered on Jul 03, 2014
if you fol;lowed all instructions and removed shipping braces then return for replacement or refund
Frigidaire... | Answered on Aug 25, 2019
Richard?
I have provided you a website that may help.
There has been a recall since 2013. Here below is the website.
My advice. Contact Gree. Be persistent and kind. Customer Support Reps, being people, can do wonders sometimes when they are treated kindly.
https://www.cpsc.gov/Recalls/2013/Gree-Recalls-12-Brands-of-Dehumidifiers/
Frigidaire... | Answered on Jun 16, 2019
Does it run after you get to the optimal humidity level?
If so, it's a bad humidity sensor switch A cheap fix is to put it on a timer. Otherwise replace the switch.
Frigidaire... | Answered on Feb 13, 2019
Good Afternoon Friend,
I understand you are looking for the owner's manual for your Frigidaire dehumidifier, model# FDL50S1. Attached is a link to your manual. Hope this is helpful.
-Best Regards-
WP
Frigidaire Manual Search Results
Frigidaire... | Answered on Dec 14, 2018
To remove the back cover, first remove the sides: two screws at bottom of side, one halfway up the back, one inside bucket opening. Also remove four screws holding the top on. Top slides forward to release, then sides slide up about 1/2 inch and pull straight out. Hooked into the front and back. Once the sides are off, the back will come off with remaining four screws.
Frigidaire... | Answered on Oct 19, 2018
Frigidaire FAD704DWD 70 Pint/Day Energy Star Dehumidifier w/ 16.3 Pint Tank Capacity, Up to 194 CFM, 115V, 2 Speeds, Antibacterial Mesh Filter, Auto Shut Off, Effortless Humidity Control, Full Tank Alert, Continuous Drain Option & Portable Design Logo
10 questions posted
Top Frigidaire Dehumidifiers Experts
Alan Chouinard
Nestor Dede
Level 1 Expert
Your Consultant
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Dehumidifiers
Most Popular Question
possible buy portable dehumidifier will
  • Dehumidifiers
