Washer had just started and i started to smell something, and all of a sudden a noise came from the washer and then smoke came from machine really bad, the noise sounded like air escaping
Re: Washer had just started and i started to smell...
Looks like something is short circuited & due to which there is burning smell coming out of the machine. Disconnect the machine immediately & inspect the insides of the machine. Locate the burnt motor or burnt wires. You heard the noise coming out of the motor. It could be dislocated brushes due to which the motor could not rotate & in turn it burnt your motor.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - 189 reviews - $32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
It sounds like the motor is heating up and tripping the overload. The squealing is probably coming from you pump. Tilt the washer back and turn the pulley for the pump by hand and if it make the squeal, replace. If it does not you may have a bad transmission.
April, You say you are suspicious that the smoke could have originated from the motor, BUT have you confirmed it? Have you tried running a short cycle without a load to see if the spin cycle rattles the machine or whether the machine works? Watch for smoke and turn off the machine immediately if you see or smell burning. If the motor is burnt, I think replacing should not be an option but rather replacing the machine should be considered.
time to replace the belt , might need a tub bearing too / tentioner pully might have froze . remove the back panel with the washer unpluged look to see if the tentioner is at its fullest possition if so replace the belt .
the smell is your clutch and the lack of draining is a clogged washer drain protector. see these at www.repairclinic.com drain protector is part 541811 and clutch is 2670. go there enter model number and scroll down to the red 100 click it and look for these part numbers.
My Kenmore front-load washer starts to make the huge noise. The noise happens during the wash cycle, but is mild. During the spin cycle, the noise becomes really loud. It looks like the drum is getting loose and hitting other part of the machine. I checked the drum, and I can sway the drum easily with my hand. So it looks some supporting structure is broken. I don't know if it is easy to open the washer to check what has been broken.
Most likely the transmission on the motor has seized and will need to be repaired.
Look under the washer, if there is black grease on the floor then its time to replace the motor and/or the transmission. If you have seen smoke then its probably the case.
