Even when I try:
P
Interrupt
C
Interrupt
14
Start
Execute
The machine still will not clear the error, nor does it restart? Are there any more solutions? Am I doing something wrong?
Thank you!!
The thermistor inside of the fuser needs to be reset before you can clear the code. If you remove the top cover of the fuser the thermistor is located on top of the upper fusser roller. It should be reset able by pushing in. Then you put in the reset code. you may want a tech to look into what caused this.
Hope that helps...
Lbcoaster
Thank you! Genius!
The machine still needs a proper service - one of the red rubber rollers has what looks like a tear in it and the paper is comining out with creases but otherwise you have fixed the actual problem!
I'm so greatful!
Thanks again!!
I have Sharp ARC160 but I could not use it be cause it kept on giving me the following message: Close the front door even when the front door is closed. Even when I try:
P
Interrupt
C
Interrupt
14
Start
Execute
The machine still will not clear the error, but it does restart and the message comes back saying close front door. I checked the front door and it is closed but I cannot pass this level. Are there any more solutions? Am I doing something wrong?
Thank you!!
My e-mail is: [email protected]
