Panasonic KX-T7730 Corded Phone Logo
Posted on Sep 12, 2011
I have a panasonic KX-T7730 DESK PHONE. THERE ARE 12 BUTTONS ALONG THE RIGHT HAND SIDE. HOW DO I PROGRAM A NUMBER IN ONE OF THESE BUTTONS?
sweet_corn_k
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 28, 2020
sweet_corn_k
Contributor
Level 1:
Answers
Questions
0
Helped
213
Points
If you want to save extension number
program + button + 1 + EXT + store
example : program + button + 1+ 103 + store
if you want to save co
program + button + 0 + co number + store
example : program + button + 0 + 1 (for co1) + store
if you want to save external number
program + button + 2 + 9 + external number + store
example : program +button+2+9+0097259970... + store
Anonymous
Level 1:
New Friend:
  • Contributor 29 Answers
  • Posted on Sep 12, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
29
Questions
0
Helped
3097
Points
85
You can contact the mobile service provider.........
5helpful
2answers
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Our office pabx is a Panasonic KX-TA616. I am trying to program personal speed dial on a Panasonic KX-T7730 (which has 12 CO buttons on the right but no Personal Feature buttons). Neither of the...
    Look carefully at the part number on the phone and where you posted. A Panasonic 7730 set has 24 buttons, 12 left side C.O. buttons and 12 right side PF buttons. A TA30830 (new style) has 12 buttons with LED's. In our country, the TA30830 needed 824 version 2 or greater software to work.
    In your country the other mate to that is the KXT-7667.
    If your phone is one of those and actually works, as in any Panasonic set, the LED buttoon requires a "2" in front of the digit sequence to tell the system it's a PF button.. So, PROG button 2+access code+number STORE saves a speed dial. The access code is what you dial to get an outside line.
    Carl
    How do I program a phone number to the one touch buttons on a Panasonic KX-T7730 phone?
    It depends on what you get when you dial "9" on the intercom. If you get an outside line, then the 12 right side buttons on your phone can be programmed for one touch dialing like this:
    On an idle phone, press PROGRAM a button and dial 9 plus the number and STORE. You can program more than one button by just pressing button numbers and STORE. Exit programming by picking up the handset and dropping it back down.
    If you want a specific line, you may be able to dial the specific 8x code to access a line directly, or you can go into system programming and delete the open lines in program 400. Disabling would be the best, because if your 8x line is busy, you can't make the call with the auto dial button.
    Carl
    How can i use the buttons of panasonic kx-t7730 corded phone ?
    The 12 buttons on the right can be used for personal speed dial numbers and features like paging. They are programmed by pressing PROGRAM dialing codes and STORE. An outside call would use an "access code" usually "9" plus the number. Paging is 330.
    The 12 left side buttons are very valuable as they have lights. You can store lines, extensions, and features that require lighted buttons, such as CID Indication or VM functions. They are programmed by PROGRAM the button a code the feature and STORE. For example, lines are programmed with 0 + line Extensions with 1 + ext and CID Indication System with 96 or the 9x voice mail commands.
    Your OM or User's manual has a section on flexible button assignment with the codes and buttons required to do the programming. In my TA-824 200-OM it's in section 3.1.3.
    Carl
    How to set name and contact number on the telephone set for one touch dialing with right buttons? My set is Panasonic KX-T7730
    It depends on what happens when you dial "9" from the intercom. If it gives you a line, then that's your "access code". If it gives you a line that doesn't exist, then you need to fix your programming.
    From the idle phone, press PROGRAM, one of the right side buttons, and dial 9 and your number and STORE. You can program one or all 12 buttons at once. When you're done, pick up the handset and drop it back down to exit programming.
    That's it.
    Carl
    I am using kx-t7730 set with pabx kx-tem824 for programming purpose. My question ia that how i programme the 10 memory button of the set it self.
    The 10 memory buttons are the first 10 buttons on the right side of the phone bottom to top. They are shared and left over from the old 70xx series. So, just program the right side buttons (PROG button dial your number STORE) and you can access them by pressing the buttons or using the keypad.
    Carl
    How do I program transfer numbers into the 12 buttons on the right hand side on my Panasonic KX-T7730?
    I'm afraid to ask what you mean by "transfer numbers". The buttons are programmed by pressing PROGRAM the button, dialing a number sequence and STORE. Here's the fear. If you're trying to :"transfer" a call outside the system, then you need to enable trunk-to-trunk calling in the box, insert an access code, usually 9, and have certain features on the line. If you're trying to put inside numbers there, especially extensions, they'd be better on the left side buttons where you can monitor them. Hint: the DSS console works wonders.
    Carl
    How do we set Personal speed dialling on KX-T7730?
    Down the right side of the phone you have 12 Personal Feature buttons. Also, from the intercom, dial "9" and see if you get an outside line. If you don't, you need to fix that in system programming.
    Now, from your phone, press PROGRAM, one of the 12 right side buttons, and dial "9" plus the number you want and STORE. You can continue programming all 12 buttons and when you're done, pick up the handset and drop it back down to exit programming.
    You dial them by pressing speakerphone or picking up the handset and pressing the button.
    Carl
    How do I set the speed dial (personal - not system) on my Panason
    A 7730 has 12 function buttons on the right side of the keypad. You can program those 12 buttons by pressing PROGRAM the button and dial an access code (usually "9") then the number and STORE.
    Carl
    How to store numbers for speed dialling on Panasonic KX-T7730 having only 12 CO buttons.
    Well let's see. You have 12 CO buttons and 12 PF buttons, and at least 100 system speed dial numbers available.
    Which ones are you looking for?
    Depending on what Panasonic system you're connected to, the PF buttons program by pressing PROGRAM and the button, and dialing the number with a "9" or trunk access code in front of it then STORE. If you're connected to a TD system it's PROGRAM 99.
    System speed dial numbers are entered from the main or manager's phone under system program 001.
    Carl
    Top Panasonic Lands Phones Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
