SOURCE: Dell optiplex Gx 150
This is a problem with your memory.
During POST, the computer checks the computer's memory, determines the amount of installed memory, and then writes to and reads from the number of available bytes to ensure proper operation.
Basic Checks:
If the problem still exists after you complete the basic checks, fill out the Diagnostic Checklist as you perform the following steps.
CAUTION: Before you perform this procedure, see "Safety Information."
Does the RAM count displayed correctly match the actual amount of memory installed in the computer?
Yes. The computer needed to update the memory count. The problem is resolved.
No. Go to step 2.
Did any of the diagnostics tests fail?
Yes. Contact Dell for technical assistance.
No. Go to step 3.
Yes. The memory module(s) were defective. The problem is resolved.
No. Contact Dell for technical assistance.
SOURCE: I have the same problem 6 beeps...I green 3 yellow lights
That beep code indicates memory is not being properly identified or used. Try removing memory and testing with one module at a time until you find the one module or slot that is causing the trouble.
SOURCE: dell inspiron 530s won't boot up and gives me 4
Dageezer is correct. I had the exact same problem. I unplugged the computer, discharged the power by pressing the power button a few times, and then opened the case. I removed one of the memory cards and tried again. This time is started to power up. I then discharged the unit again and re-seated the memory card I took out. Turned on the power again and now everything works. Not sure why it stopped working to begin with, since I haven't had any problems in over 2 years, but now it's OK (for now). Thanks.
WAKE THE WASHER BY PRESSING ANY BUTTON.
WAIT 5 SECONDS.
PRESS AND HOLD THE START AND PAUSE/CANCEL BUTTONS
SIMULTANEOUSLY.
ALL LED'S WILL GO BLANK AND AFTER A FEW SECONDS THE CONTROL
WILL SIGNAL THE STORED CODE USING AUDIBLE BEEPS AND BLINKING LED'S. THE CONTROL
WILL REPEATEDLY SIGNAL THE CODE, AS LONG AS THE START AND PAUSE/CANCEL BUTTONS
ARE PRESSED. A TWO-SECOND PAUSE BETWEEN REPEATS AFFORDS YOU THE ABILITY TO MAKE
ACCURATE COUNTS TO IDENTIFY THE CORRECT ERROR CODES.
PLEASE NOTE THE FOLLOWING: ON A SMALL NUMBER OF WASHERS WITH
SERIAL
NUMBER PREFIX XC4, IF THE PREVIOUS PROCEDURE DOES NOT PREFORM
AS
SPECIFIED, FOLLOW THE OPTION BELOW:
* FOLLOW ALL PREVIOUS STEPS BUT INSTEAD OF PRESSING START AND
PAUSE/CANCEL BUTTONS, PRESS AND HOLD OPTIONS AND PAUSE/CANCEL BUTTONS."
*THE CONTROL WILL PAUSE FOR 2 SECONDS, THEN REPEAT THE CODE AS
LONG AS THE TWO BUTTONS ARE PRESSED AND HELD."
NOTE: A LETTER APPEARING IN THE CODE STANDS FOR A NUMBER HIGHER
THAN NINE: A=10 B=11 C=12
D=13 E=14 F=15
"EXAMPLE CODE F1: THE FIRST
DIGIT WOULD BE 15 AND THE SECOND WOULD BE 1. IF THIS CODE WOULD APPEAR ON A
WASHER IN THE GOOD MODEL LINE, THE FIVE INDICATOR LIGHTS WOULD BLINK FIFTEEN
TIMES AND THE START INDICATOR LIGHT WOULD
