Would help to know what column. Is it the old round column???
Is it tilt and is it moving about where it tilts?
If yes, the column can stay in the vehicle. You will need some specific tools to do this. Amoung other tools you need, a steering wheel puller, Lock plate tool, possiby male torx bits/drivers (depending on year), for certain torx female socket and a tilt pin removal tool.
And it is somewhat a complex job for someone that has not done it before.
REMOVAL & INSTALLATION
The steering lock/ignition switch/warning buzzer switch assembly is attached to the steering column by special bolts whose heads shear off upon installation. The bolts must be drilled out to remove the assembly or be removed with an appropriate tool. The bolts may also be removed with a hammer and chisel by notching the bolts and tapping them counterclockwise with the hammer and chisel.
The ignition switch or warning switch can be replaced without removing the steering lock assembly. The ignition switch is on the back of the assembly and the warning switch is on the side.
CAUTION
The models covered by this guide may be equipped with a Supplemental Restraint System (SRS), which uses an air bag. Whenever working near any of the SRS components, such as the impact sensors, the air bag module, steering column and instrument panel, disable the SRS, as described in Chassis Electrical .
