Toshiba Satellite p105-S6114 Notebook Logo
Posted on Aug 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Download graphics card for Toshiba Satellite P105-S6114
Anonymous
Level 3:
  • Toshiba Master 32,281 Answers
  • Posted on Aug 30, 2011
Anonymous
Toshiba Master
Level 3:
Answers
32281
Questions
Helped
7913482
Points
102259
You can download thevideo and device drivers for your model laptop from the Toshiba WEB site from theirdownload page. Make sure you enter the model of your laptop so you can get thecorrect drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Need audeo driver
Vista and XP drivers are available here - http://support.toshiba.com/support/modelHome?freeText=1484717. I am unable to find Windows 7 or later.
Power cord doesn't make good connection, feels like something is loose inside. Please help
its probably the dc jack--common problem on laptops--needs to be resoldered--takes about 1 hour
2answers
How do i resart my Toshiba Satellite P105-S6114 to factory settings without the recovery discs?
Quite simply, you cant. You would normally do this by inserting the original recovery disc in the cd drive and press F12 as you turn it on.
The only options available are asking Toshiba for the discs (for which they might charge) or see if you can find someone with the same machine and borrow theirs.
2answers
Can graphics card installed to toshiba satellite L510
If you are asking if you can upgrade your laptop video card the answer is NO. Your laptop came with an INTEGRATED Intel Video card. Not possible to upgrade or install a different graphics card
I have a Toshiba Satelliet P105-S6114 my dvd rom does not work is it very hard to replace
open cd rom door just clean lense with soft cloth ...if same
remove cd rom romove top cover then romove buttom u can see on back of lense two veriable for lense adjustment try one by one one adjustment is for normal cd and one is for dvd cd dont try together.. move little bit...and clsoe and then check... Thanks
I have a Toshiba satelite P105-s6114 and it is asking for a default password when I turn on... do you know what that password is or how I bypass???
Passwords are designed to keep people out!
default meants the password that was set by the owner. Initially there is no password. So someone has set one up.
The person who put the password in is the one who can open it. Sorry
1helpful
Model Numbers - Duplicate
No that is not true. Each manufacturer assigns the model and serial numbers regardless of where you purchased it.
Here is the # for Costco's Concierge service (Tech Support):
866.861.0450
Also, you can download Belarc Advisor, and it will scan your laptop. Not only will it tell you your model and serial #, it will tell you your license #'s for your programs and it will tell you everything that is installed on the laptop. Download it from this link:
http://www.belarc.com/free_download.html
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Audio level: satellite p105 s6114, conexant high definition audio
perhaps you need to adjust the master settings through control panel, sounds?
3answers
Toshiba P105 S6104
Hi Ed;
This is issue has resolution as it has been published on Toshiba's Official Support Website. It seems you need to go to an Authorized Toshiba Center. They have a special tool to re-flash your BIOS and it will resolve the issue. I am adding the original text and link for the solution below
Good Luck
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=1827224xml&sliceId=&dialogID=24612375&stateId=1%200%2024610494
New BIOS fixes incorrect power-on password prompt Document ID: 98082329 Posted Date: 08/21/07 Last Updated: 08/21/07 Category: ACPI, BIOS, Password Distribution: Public Applicable Models: Satellite P100-ST7111, P100-ST7211, P100-ST9212, P100-ST9612, P100-ST9412, P100-ST1071, P100-ST9732, P100-ST1072, P100-ST9762, P100-ST9772, P100-ST9752, P100-ST9742, P100-ST9712, P100-ST9012, P105-S921, P105-S9312, P105-S6074, P105-S6034, P105-S6124, P105-S6114, P105-S6104, P105-S6102, P105-S9722, P105-S6062, P105-S6022, P105-S6084, P105-S6064, P105-S9339, P105-S9337, P105-S6227, P105-S6217, P105-S6158, P105-S6148, P105-S6207, P105-S6197, P105-S6187, P105-S6177, P105-S6167, P105-S6157, P105-S6147, P105-S6134, P105-S6024, P105-S6054, P105-S6014, P105-S6004, P105-S6012, P105-S6002, P105-S931 << hide Use of any software made available for download from this system constitutes your acceptance of the Export Control Terms and the terms in the Toshiba end-user license agreement both of which you can view before downloading any such software.
Issue
The computer models listed above may display a "Password =" prompt when the computer is turned on, even though no power-on password has been set. If this happens, there is no password that will satisfy the password request. If the computer is turned off and back on again, it is very likely that the same password prompt will appear. The computer will be unusable until this problem is fixed.
If the problem has not happened yet, you can prevent it from happening in the future by upgrading the BIOS to the newest version.
The occurrence of this problem on any particular computer is unpredictable -- it may never happen, but it could happen any time that the computer is turned on. If this problem does occur, it will be necessary to send the computer to a Toshiba Authorized Service Provider, who will fix the problem at no charge to you.
Resolution
If this problem has not yet occurred on your computer, then click the following link to download and install BIOS version 4.00. This BIOS displays a power-on password prompt only when a power-on password has actually been set via the BIOS Setup program.
You may also browse for a newer version of the computer's BIOS at pcsupport.toshiba.com.
For more help, see Support Bulletin 98081213 Obtaining downloads and support docs from the Toshiba Support website.
If the problem has already occurred on your computer, then please make arrangements with a Toshiba Authorized Service Provider to have this problem fixed at no charge. To locate a Toshiba Authorized Service Provider (ASP), please visit Toshiba's Global ASP Locator at http://pcrepair.toshiba.com.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
