Sharp R-510HW Microwave Oven Logo
Posted on Aug 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The microwave will not come on ,however the timer starts running . If you hold the latch in slightly it will run correctly but you have to keep it pressed in. I have the sharp carousel model 1200watt
Sagar Patel
Level 2:
New Friend:
  • Expert 107 Answers
  • Posted on Aug 28, 2011
Sagar Patel
Expert
Level 2:
New Friend:
Answers
107
Questions
Helped
41861
Points
199
Your door is misaligned dont use it by holding it Ionce you tighten the door correctly then adjust the door switch where the door latches and make click sound Thanks Please rate me
Microwave runs for 3 seconds and shuts off
Keep pressure on the door and see if will continue to run if so you might have a weak spring in the door latch this would allow the door to pull back slightly and not activate the door switches.
Why does Microwave count down but will not run?
Sounds like a door switch is not closing; either primary or secondary. You could have either a bad switch, or the latch assembly is not aligned properly.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Hi, I have a Kenmore 87103 microwave and it has started acting up lately. When I place something in the microwave and set the timer, the timer counts down however the microwave doesn't work (no sound and...
Mine also does the same thing however I only need to lift the door upwards slightly (after it's closed) and it engages the High Voltage Transformer, thus working as normal.
Once you know that, you can get it to work every time. I beleive the clips on the door don't properly stop latch in correctly and the safety feature keep the microwave from acutally turning truly "ON".
1helpful
My GE 1660 profile microwave oven will not cook or rotate, but the timer reduces in time. I have tried to gently press up or down on the door in case it is a door latch issue with not change. Also it keeps...
Check the door safety interlock switches. If they are burned (because you frequently open the door while the oven is running) they tell the magnatron that the door is open (forget what you know about the door) and not to run that magnatron (which produces the microwaves that actually heat the contents of your oven).
Check the switches with a ohm meter. Remove the cover to find the switches near the door latches.
Thank you for your interest in FixYa.com
When we close the door the motor keeps running.
This just started happening on my Kenmore microwave because the door latch broke off.
Microwave Will not Run
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
You will need to remove the outer cover, then shut the door and then you can adjust the door latches.
2answers
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Top Sharp Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
