after 2 years using this receiver, it started to freak me out. The problem is, several minutes after I turn it on, the left speaker output starts disconnecting. One time there is sound on the speaker, some time there is not. I've check the speakers, there are not the problem.
Some solution? Or I need to take it to service. :)
Thanks in advance.
SOURCE: Pioneer VSX-D608 Optical connection
Do you have the original remote for the receiver? You need the remote to set up the optical settings according to the manual there is a fair bit of things to do to set it up reply if you do have the remote then I will post up word for word on how to change the settings but without the remote you basically cant do much with it sorry
hope this helps
SOURCE: Pioneer vsx-5300 reciever
If you have just one pair of speakers hooked up and have both A & B speakers selected you won't get ANY sound out of unit, so check that?
SOURCE: problem with pioneer vsx-916 av receiver
i have been using this with two speakers and was working perfectly fine . recently i bought two floor standing speakers and worked fine when connected . When i tried connecting all four speakers it showed overload kindly tell me how this could be solved
SOURCE: Pioneer VSX 818V No Sound
First thing to check is the Speaker Select Switch. It will say, "A" "AB" or "Both" it will be displayed on the LCD screen as well. Second if that's ok, Check the "Direct" switch. If it's on, turn it off. Generally if it's on, you will see a blue light if it's on (most receiver's)
If you still have No audio, hook up your DVD to the "Direct" input and turn "Direct" on. If you have audio then. The DSP chip is probably bad and you should take it to a shop and have them bench it first to confirm. Hope this helps
Testimonial: "Got me on right path, but I'm still stuck."
SOURCE: pioneer receiver vsx-d510 sub not working
Rear Surrounds are not supported on this unit, they would be the 6th and 7th channels in a 7.1 rig. I think you mean Surrounds (channels 4 and 5 in a 5.1 rig).
Lets ponder: How is there any relationship between Surrounds and your separately-amplified Subwoofer? I don't see it, unless you inadvertently chose OFF for the Sub definition when you were in the Speaker selection menus adding the Surrounds. Look again.
i have the same problem on my 916, but when i turn up the volume in a flash, it opens up. after that it is fine for a few hours and it comes back.
I've got the same problem, but the right speaker. Some times I have to hit the receiver to get it going, What's the deal with this?
I have the same issue but the right speaker. Sometimes I have to hit the receiver to get it working. What's the deal with this.
