Have you tried NOT connecting your camera to your computer? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.Have you tried NOT connecting your camera to your computer? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
You can't post conmments that contain an email address.
I finally got one to work by 1) Disconnect the unit from your computer. 2)turning the unit off, 3) Reset the unit using a pin or small object. 4)Now reconnect to your computer.
I preformed this procedure and finally was able to load photo's and get the pre-loaded software to work.
What kind of camera? I have a Kodak M1033 And All I did was plug it in. Or to get the pictures/video you can get the SD card and insert it in the slots. You have options. Try them ;]
Installed macromedia flash player. After a short period of time, left plugged in and running, wizard detection of new program kicked in and went through series of setups. Screen stays small but does allow to download to computer.
I had the same problem on a 128 mb memory. I figured out that it can only load a certain # of objects/files. So I started from scratch, and I created a new folder in the pandigital and copied all the files/photos/mp3's into that 1 folder. Thus 1 object. I was able to fill the entire capacity after that. I can't believe I actually helped solve one! I hope it works for you...
sir, i have a sony handycam [dcr-trv 285e- pal].but problem is software given is not getting installed in my laptop with windows vista. so iam unable to use movie maker trough my computer.so please do the needfull. th
Software not loading in my pc with widdows vista
thanking you.
The Coby DP-887 does not have built in memory so one cannot "load" pictures onto it. It is a viewer in every sense of the word. If you load pictures on a flash drive or memoory stick and plug that into the Coby DP-887 then you'll be able to view pictures or video.
