SOURCE: 2004 r1 RIGHT TURN SIGNALS DONT WORK
the relay is at fault change it and you should be good to make all the right turns
SOURCE: Can you straighten torqued front forks on a 2002 Yamaha TTR 125 L
you should be able to saporrt bike so front wheel is off the ground then take a marker and put lines around where the forks meet the triple trees that hold them in place their should be some allen head bolts that u can loosen on front of the triple clamps once these are loose you should be able to move the forks back to strait again in line with the handle bars just line the lines up that u put on them earlier and tighten the allen bolts back up also when making the lines make them from left to right so marker is touching both fork tube and triple clamp this is only so you get can keep them the same ride hight as before
SOURCE: integrated tail problem
firstly ground them two wires and see what happens
you have got something screwed up if you gotta take fuses out to get stuff to work.
i find it easy if i draw what i have on paper first. you should have 3 wires for tail and 2 each for turns. those maybe 3 blacks, 1 green, 1 brown, 1 blue, 1 yellow.
http://www.carlsalter.com/motorcycle-manuals.asp
you can get a free download service manual here it will have the correct wiring diagrams for your bike. it shoudl help
SOURCE: i need a repair manual but i cant find one on the web in a pdf.
HAVE YOU TRIED THIS LINK?
http://www.venturers.org/Tech_Library/
SOURCE: Shake from left to right at high speeds.
Check for steering head bearing problems. But most likely you have a cruiser that is not supposed to be driven at high speeds and this is normal. Sport bikes use a steering dampner to solve that problem.
