20 Most Recent
Hunter 25658 Lancaster Antique Black Ceiling Fan Questions & Answers
Hunter fan remote control 99600 not working
This must be a common problem, since I Googled the part number and it popped up before I completed the number. I am going to have to order a new remote, since I don't have a solder pen. Wish me luck.
11/22/2023 10:57:54 AM •
Hunter Dryers
Answered
on Nov 22, 2023
Programmable Hunter 44150B display has "?" Above heat. What does this mean?
The "?" symbol above the "heat" setting on a programmable Hunter 44150B thermostat display indicates that there is a problem with the heating system. The thermostat is unable to detect whether the heating system is working correctly or not.
There could be several reasons why the thermostat is displaying the "?" symbol above "heat", such as:
- The thermostat may be malfunctioning and unable to properly communicate with the heating system.
- The heating system may be experiencing an issue or malfunction, which is causing it to not work properly.
- The thermostat may not be properly connected to the heating system, which is causing communication errors.
To troubleshoot this issue, you can try the following steps:
- Check the heating system to see if it is working properly. If it is not, you may need to call a professional technician to diagnose and fix the issue.
- Check the wiring and connections between the thermostat and the heating system to ensure they are properly connected.
- Reset the thermostat by turning off the power to the thermostat for a few minutes and then turning it back on. This can sometimes resolve communication errors.
If these steps do not resolve the issue, you may need to contact a professional technician to diagnose and fix the problem with your heating system or thermostat.
