20 Most Recent Maytag MDB4621A Built-in Dishwasher Questions & Answers
Power to washer but will not turn on no lights or
make sure the door latch is working properly. If the latch isn't latching, then it won't turn on.
3/10/2009 8:50:43 PM • Maytag MDB4621A... • Answered on Mar 10, 2009
Grinding noise - Maytag dishwasher MDB7100
I suspect something hard like a fragment of chicken bone or a citrus seed is at the inlet to the drain pump (my favorite was a plastic pull strip from a frozen juice concentrate can - that was LOUD). Many dishwashers have a chopper similar to that in a garbage disposal right before the pump inlet, but some things like bone won't go through it. It could be something light enough to float and only hits the pump when the water level drops. You may have to remove the pump cover in the bottom of the dishwasher to find it. This would be a good time to clean any garbage out of the lower spray arm and check the spray arm bushing for excess wear.
2/5/2024 6:01:23 PM • Maytag... • Answered on Feb 05, 2024
2answers
My Maytag quiet series 200 is not cleaning and despite many attempts it is also leaving terrible residue on dishes.
I found this on ehow I believe it will help. How to Troubleshoot Dishwasher Residue By Dale Yalanovsky eHow Contributor 5Found This HelpfulGeorge Doyle/Stockbyte/Getty images Dishwater residue is a fairly common occurrence, and several things can cause it. Even the newest dishwashers may leave residue, and it might have nothing to do with the actual dishwasher function itself. However, there are things you can do to prevent, limit or completely remove dishwasher residue during every washing cycle.
Other People Are Reading
  1. Detergent Residue
    • Modern phosphate-free detergents are the main culprits when it comes to detergent residue. After every wash, many leave a slight whitish residue behind. After several washings, the residue becomes caked on and leaves a noticeable white tint to your dishes. Some dishwasher detergent brands are better than others, and either minimize residue or do not leave any. Once residue is present, however, the only way to remove it is by hand scrubbing or scraping.
    Hard-Water Residue
    • Hard-water residue comes from non-softened water from your hot water tank. Non-softened water leaves a white tint on dishes, but no amount of scrubbing will remove it. Only by wiping a small patch of the dish with vinegar or lemon juice will you be able to ascertain whether the white residue left is hard water or detergent. The slight acidic action of the vinegar or lemon juice removes hard-water stains, but they have no effect on detergent residue.
    Greasy Residue
    • If the dishes feel greasy when they come out of the dishwasher freshly washed, you are dealing with a greasy residue. There are two main reasons for this: either the detergent is not an effective grease remover, or the hot water inside of the dishwasher, either from the hot water tank or the dishwasher's heating elements, is not hot enough. Boosting the hot water temperature on the water tank may solve the problem, and a second wash cycle may be needed for the dishes. A preventive measure of running the dishwasher empty with a full load of detergent also removes the residue inside of the dishwasher.
    Streaking and Spotting Residue
    • If you have spotting or streaking on your dishes, that may be a sign you need a rinse agent. Many modern dishwashers recommend a rinse agent to prevent spotting or streaking, and without one, your dishes will never be crystal clear or streak-free. The next time you do a dishwasher load, add a rinse agent. If the dishes come out spot- and streak-free, the problem is solved.
Read more : http://www.ehow.com/info_12285021_troubleshoot-dishwasher-residue.html
1/4/2024 7:07:34 PM • Maytag... • Answered on Jan 04, 2024
Maytag dishwasher clean light is blinking and it won't start
This is caused from a power cut or by the door being opened during a mid cycle.Or from a power cut.
7/18/2023 9:29:46 AM • Maytag... • Answered on Jul 18, 2023
My Maytag dishwasher turns on and runs for just under 2 minutes. At this point it switches off and shows 2 minutes remaining on the cycle as it drains out.
i don't know. sounds like a fault in the program. consider unplugging machine for 10 mintes. plug it back in and run a short wash to see if the program has reset itself. if not OK, call for repair estimate then decide if you can live with it as is,-- have someone try to repairit -- or replace it with a new one which may offer extended warranty for $$.
8/29/2022 8:06:11 PM • Maytag... • Answered on Aug 29, 2022
2answers
Maytag dishwasher installation problem
You will need a new hose that is longer for your dishwasher and a new water pipe and a new hose installed for the dishwasher to run.
6/26/2022 7:37:12 AM • Maytag... • Answered on Jun 26, 2022
Maytag Quiet series 300 Handle and latch seem broken
google Maytag Quiet series 300 Handle and latch there are several new handles about $30-35. link to how to replace handle copy and paste https://www.youtube.com/watch?v=Tfw0F5XeWHY ..
6/14/2022 2:15:44 PM • Maytag... • Answered on Jun 14, 2022
Older maytag dishwasher- pf signal post power outage - does not have on/off switch- how to restart
no info generic answer unplug or disconnect power
3/28/2022 8:08:14 PM • Maytag... • Answered on Mar 28, 2022
What are dimensions for Maytag dishwasher Model # DWU7400AAX?
google maytag dwu7400aax dimensions for your answer less than 3 seconds. This is just a standard size dishwasher model. Dishwashers in general are going to be standard size unless you get a portable dishwasher or a 30 inch wide dishwasher. There are very few of these models. Your size dishwasher is just 24" wide 24" deep and 34 1/2 inches tall but the height can be adjusted somewhat
12/27/2021 7:58:42 PM • Maytag... • Answered on Dec 27, 2021
I have a Maytag dishwasher and the water is not coming in? How to fix it?
BAD CONTROLLER OR WATER VALVE
9/2/2021 6:33:14 PM • Maytag... • Answered on Sep 02, 2021
My maytag W10199645 dishwasher won't start and no lights on
Those units are shipped without a power cord so they can be hard wired into a conduit box. Check the power cord where it is wired into the box ON THE MACHINE and make sure all the connections are correct and are secure.
8/14/2021 4:23:17 PM • Maytag... • Answered on Aug 14, 2021
What might be the problem with my Maytag Dishwasher Series 300 fail to work
Almost anything can cause that. Be specific and we will hazard a guess.
2/7/2021 3:32:36 PM • Maytag... • Answered on Feb 07, 2021
Parts for Maytag model dfc5000aax disposer needed. tailpipe mount for discharge tube
Contact Maytag and/or an appliance parts supplier to inquire.
12/31/2020 3:15:26 PM • Maytag... • Answered on Dec 31, 2020
I have a 1 year
Perhaps a safety switch somewhere. I would check inside for a utensil that fell down into the impeller or the like. Also look at the door latch area; maybe a switch there is not closing properly.
10/25/2020 4:32:17 PM • Maytag... • Answered on Oct 25, 2020
2answers
Maytag dishwasher MB4949SHB. Is it possible to control the brightness of the LED lights on control panel?
check power supply voltage if ok bad display
9/12/2020 8:17:33 AM • Maytag... • Answered on Sep 12, 2020
Maytag mdb6100 not emptying light blinking won't turn on
To reset those you need to interrupt the power to the unit, you can do this by finding the breaker it is on and turning it off for a minute or two. Then try again and let us know
7/22/2020 4:25:48 PM • Maytag... • Answered on Jul 22, 2020
Maytag dishwasher runs for 4 seconds and stops. FIELD SERVICE CHECK did not render the promised 2 lights flashing to show what was at fault - feel its the turbidity sensor- HOW CAN I BE SURE>
I am not familiar with the model but I doubt it - few people these days use the highly inefficient soap dispenser, preferring to add detergent directly into the wash drum. I suggest you read the instruction booklet.
3/8/2020 8:23:01 PM • Maytag... • Answered on Mar 08, 2020
My dishwasher model #mdb4651wont shut off
Sorry I only have more questions. If you observe the following things it may help rule out the thermostat or heating element . There are similarities to my problem. My dishwasher run for 4 seconds and stops briefly and starts again and will do that for ever. 1. Will it run properly in RINSE ONLY mode? 2. Does it run constantly or stop /starts continuously? 3. Does the soap dispenser open? 4. Does the timer count down? Ie cycle reads 2H and counts down, at least on my model. 5. Finally noticing if all the normal sequencing is happening. Ie turns on, pump empties the dishwasher, fill occurs, arms spin, and so forth. you should be able hear the unit empty and refill again and the rinse light goes on. Sorry I could'nt be more help but possibly we can help each other.
3/7/2020 4:35:24 PM • Maytag... • Answered on Mar 07, 2020
Maytag MDB4621A Built-in Dishwasher Logo
2 questions posted
Top Maytag Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Maytag Dishwashers
  • Maytag Dishwashers
Most Popular Question
power washer but will not turn no lights
  • Dishwashers
