Question about Maytag Dishwashers
My dishwasher model #mdb4651wont shut off - Maytag Dishwashers
Posted by Ken Karl on
Brian Burrell
    Habit-Forming:
  • 8 Answers
Sorry I only have more questions. If you observe the following things it may help rule out the thermostat or heating element . There are similarities to my problem. My dishwasher run for 4 seconds and stops briefly and starts again and will do that for ever.
1. Will it run properly in RINSE ONLY mode?
2. Does it run constantly or stop /starts continuously?
3. Does the soap dispenser open?
4. Does the timer count down? Ie cycle reads 2H and counts down, at least on my model.
5. Finally noticing if all the normal sequencing is happening. Ie turns on, pump empties the dishwasher, fill occurs, arms spin, and so forth. you should be able hear the unit empty and refill again and the rinse light goes on.
Sorry I could'nt be more help but possibly we can help each other.
Posted on Mar 07, 2020
Frigidaire FFB240 dishwasher won't stop
Good Morning AA1970,
I see that you are having trouble with your Frigidaire dishwasher, model# FFB240, continuing to run unless you shut it off. While I'm not familiar with this particular model number, I suggest that you give the appliance a hard reset. You will do this by shutting the power off at the circuit breaker for at least 20-30 minutes. After restoring power, run the cycle. If it is still continuing to run unless you shut it off, I suggest contacting a local authorized technician for further assistance.
-Best Regards-
WP
Apr 01, 2014 | Frigidaire FFBD2406NS Built In Dishwashers
Dishwasher not draining
I am not familiar with this model, but in general, dishwashers have a grill or trap at the bottom near the back usually and it's held down by screws. SHUT THE POWER AT THE BREAKER PANEL AND SHUT THE WATER SUPPLY OFF! Then check the type of fastener and remove the cover. If it is obstructed by food debris, you'll see it there. Good luck and let me know if this helped.
Mar 29, 2013 | GE Dishwashers
My Bosch dishwasher door will not shut Model: SHX85E15UC/01
Can not find anything for the model number you have indicated. Can you check ENr and repost pls.
Mar 22, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
My dishwasher door will not stay up unless locked. I have installed new springs, to no avail
Might help with solution if you provide make and model number of dishwasher.
Sometimes the solution is a simple as ensuring the dishwasher is level so that the door shuts. The spring tension may need adjustment and usually there are a few screws at the top of dishwasher panel. Depends on make and model.
Jan 05, 2013 | Dishwashers
Dishwasher tablet not dissolving during wash cycle
I am not sure if you can use dishwashing tablets with this model of dishwasher. These are designed mainly for powder only - you should be able to shut the detergent compartment door before starting the dishwasher.
Make sure the compartment is not blocked preventing inlet water from circulating through.
Dec 30, 2012 | Fisher and Paykel Dishwashers
Will a clogged drain hose cause the washer to shut off ?
That might be a problem if there is water build up on the bottom but if its shutting off I dont think it will do that unless it is a new model. You could have a component going out if its an older model. If the entire washer is going out it might be your dishwashers electrical circuitry. Hope this has helped, good luck
Jul 14, 2009 | GE Nautilus 24" Built-in Dishwasher
Door on Hotpoint Diswasher BF1620 won't shut
To better assist you I need the Hotpoint Model n serial # look like this;
HDA3540NSA Hotpoint® Built-In Dishwasher HDA3500NWW Hotpoint® Built-In Dishwasher HDA3500NCC Hotpoint® Built-In Dishwasher HDA3500NBB Hotpoint® Built-In Dishwasher HLD4040NSA Hotpoint® Built-In Dishwasher HLD4000NWW Hotpoint® Built-In Dishwasher HLD4000NBB Hotpoint® Built-In Dishwasher HDA1100NWH Hotpoint® Built-In Dishwasher
Let me know wish one is yours.
Thank you
May 13, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Dishwashers Logo
154 people viewed this question
Top Maytag Dishwashers Experts
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
