Question about Maytag Dishwashers
Maytag mdb6100 not emptying light blinking won't turn on
Posted by Sylvia Worthy on
  • Maytag Master
  • 18,403 Answers
To reset those you need to interrupt the power to the unit, you can do this by finding the breaker it is on and turning it off for a minute or two. Then try again and let us know
Posted on Jul 22, 2020
1 Related Answer
EllaWatson25
Ella Watson
  • 725 Answers
SOURCE: have a maytag mdb6100 how do i get accsess to
You have to remove the screws in the bottom filter where the spray arm is. Before you do that, you can put a cup of Tang Orange Juice Powder in the unit without any dishes and it will clean it out unless it has plastic or glass pieces in it. Or you can use Dishwasher Magic. We have parts and supplies if you'd like to call us. Hope this works out well for you! Ella
Posted on Aug 26, 2009
Fuel sender lr3
horn won,t blow, backup light won,t come on
Jul 22, 2013 | Cars & Trucks
Washer Control Locked blinking and won't washer won't work
Water still in the bottom of the drum. Empty, clean filter and check pump is turning. Once pressure switch is satisfied no water is left it'll allow the door to open, assuming the door interlock is still ok.
May 19, 2012 | Washing Machines
Power light is blinking and the system will not run
The blinking power light indicates that the water collection tank needs to be emptied. Be sure to turn the unit OFF & unplug it, before draining the tank. And while you're at it, now would be a good time to remove and clean the air intake filter. Once these 2 things are completed, the unit should run as designed.
Thanks for choosing FixYa.
Sep 06, 2011 | Maytag NMPEB08F2A Air Conditioner
My dehumidifier full light is on but the unit is empty and the fan motor won't work. Is there a way to reset it? Is that why the fan motor won't work?
This is generally causes by improperly installing the water collection bucket after removing it to empty it. Or the float valve in the top ow the water bucket s stuck in the "UP" position. Some Maytag models have a float control that moves from left to right, depending on how much water you want it to collect, before having to empty it. It may be stuck in the center position and needs to be moved left or right.
When installing the bucket, be sure that it fits into the holder "squarely" from top to bottom and makes contact with the bucket removal safety switch at the back of the bucket holder. When installed properly, the bucket should not tilt down at the bottom.
Hope this helps you and thanks for choosing FixYa.
Aug 06, 2011 | Maytag Dehumidifiers
Filter replace light won't go out after you replace the filter
It is very easy to reset your filter indicator light on your Maytag refrigerator. Simply press and hold the light and lock buttons, on the dispenser, for about three (3) seconds, until the change filter light blinks.
Rate if helpful, Sea Breeze
Jul 08, 2011 | Maytag Refrigerators
I have a maytag MDB6100 with 2 problems
If nothing obvious like blocked / obstructed outlet pipe
You need to check if the outlet pump motor in line with the outlet hose is spinning when in the outlet mode. First check if it is spinning by looking at it and see if the small fan is spinning. If it is turnning this means that it has power and the internal "impeler" that pushes the water out has become loose. Remove the pump (easy job) and repair. If it does not spin you need to determine if the 2 push on terminals have power on. If there is voltage and the motor does nut spin this indicates that the pump motor is open circuit and must be replaced.
Mar 26, 2010 | Maytag MDB5100 Dishwasher
Full light keeps blinking on Maytag dehumidifier
pull out the tank and see if you can find the switch that actuates that fault.... it may be the float swich for the bucket and it may be stuck... flip the float switch up and down a few times
Jul 20, 2008 | Maytag M7DH45B2A Dehumidifier
Electronics problem with Maytag Dishwasher
the outlet pump may have become clogged, try removing and cleaning it.
Mar 26, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
Dishwashers Logo
120 people viewed this question
Top Maytag Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
