20 Most Recent Haier HVW18A Wine Cooler Questions & Answers
My Haier HVW18 Wine Cellar has a top fan which
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
9/27/2011 9:26:19 PM • Haier HVW18A... • Answered on Sep 27, 2011
Haier model HVF042ABL freezing temperatures and wine bottles exploding.
Steve, Have checked around the web for parts..ie temp sensor, control board, which would cause your problem if defective, and there are no parts avalible. NUTS!
2/27/2023 4:31:11 PM • Haier... • Answered on Feb 27, 2023
Fan Not Coming On & Compressor Is Hot
Ckecked around for the fan, parts for this unit are few and far between did locate some on ebay so head over there. Cuz there were quite a few but without seeing yours I couldn't match up what I was seeing.
1/22/2023 3:49:52 PM • Haier... • Answered on Jan 22, 2023
My haier 10.5 model 10TG31SW is not cooling neither top or bottom any clues
If your Haier 10.5 model 10TG31SW refrigerator is not cooling, there could be a few different issues causing the problem. Here are a few things you can check:
  1. Check the thermostat: Ensure that the thermostat is set to the appropriate temperature. If it is set too low, the fridge will not cool properly.
  2. Check the condenser coils: The condenser coils may be dirty or clogged, preventing the refrigerator from cooling properly. Clean the coils with a brush or vacuum.
  3. Check the door seal: Make sure the door seal is tight and not damaged. If the seal is not tight, cold air will escape and the refrigerator will not cool properly.
  4. Check the evaporator fan motor: If the evaporator fan motor is not functioning properly, it could cause the refrigerator not to cool.
  5. Check the compressor: If the compressor is not functioning properly, the refrigerator will not cool. It may need to be replaced by a professional.
  6. Check the refrigerant level: If the refrigerant level is low, it can cause the cooling system to fail. This is a job that should be done by a professional with the right equipment and experience.
  7. Check the defrost system: If the defrost system is not working properly, the evaporator coils will frost over and the refrigeration will not work.
  8. Check the power supply: Make sure the fridge is properly plugged in and that the outlet has power.
Please note that it's also possible that there could be other issues causing your refrigerator not to cool, so it may be best to seek the help of a professional if the above steps do not resolve the problem.
1/22/2023 3:20:45 PM • Haier... • Answered on Jan 22, 2023
Is there any way I can delete the alarm beep when doors are left open on my new Haier fridge HSBS610IS please?
It depends on the model of your Haier refrigerator. Many newer models of Haier refrigerators have a feature to disable the alarm beep when the doors are left open. To disable the alarm beep, you will need to check the user manual of your refrigerator for specific instructions on how to do this, as the process may vary depending on the model. Here are a few general steps that could help you to disable the alarm beep:
  1. Look for a button or switch labeled "alarm" or "door alarm" on the control panel of your refrigerator.
  2. Press and hold the button or switch for a few seconds until the alarm stops beeping. This should disable the door alarm.
  3. In some models, you can disable it through the settings menu of the control panel, look for the alarm setting and turn it off.
  4. Look for the manual of your refrigerator, it should have the information on how to do it.
If you can't find a way to disable the alarm beep, or you are not comfortable with following the instructions, it's best to contact the manufacturer or a professional for further assistance.
1/22/2023 3:18:34 PM • Haier... • Answered on Jan 22, 2023
The wire that fixes to freezer compartment with a metal prong has come adrift
It sounds like the wire you're describing is the defrost thermostat. The defrost thermostat is responsible for controlling the defrost cycle of the refrigerator. The flat piece of metal with hooks at each end that you mentioned is likely the clip that attaches the thermostat to the evaporator coils in the freezer compartment. To reattach the thermostat, you will need to follow these steps:
  1. Locate the evaporator coils in the freezer compartment. The coils are typically located in the back of the freezer.
  2. Carefully place the hooks of the clip onto the evaporator coils.
  3. Insert the metal prong on the end of the thermostat wire into the clip.
  4. Ensure the wire is properly seated in the clip and that the clip is securely fastened to the evaporator coils.
  5. Put back the cover panel of the freezer compartment
  6. Check that the thermostat wire is not pinched or crimped and that it has enough slack to move freely.
  7. Plug the refrigerator back in and turn it on.
It's important to note that working with the refrigeration system could be dangerous and it's always recommended to contact a professional if you're not comfortable with the task.
1/22/2023 3:12:11 PM • Haier... • Answered on Jan 22, 2023
Deep freezer not freezing food and keeps making a clicking sound.
It sounds like your Haier deep freezer is having an issue with the compressor and cooling system. Here are a few things you can check:
  1. Check the compressor: Make sure the compressor is running and not too hot to the touch. If the compressor is not running or is hot, it may be faulty and will need to be replaced.
  2. Check the compressor's overload protector: The overload protector may have tripped, check to see if it is tripped and reset it if necessary.
  3. Check the compressor's capacitors: They could be damaged and need replacing.
  4. Check the evaporator fan motor: If the evaporator fan motor is not functioning properly, it could cause the freezer not to freeze.
  5. Check the defrost system: If the defrost system is not working properly, the evaporator coils will frost over and the refrigeration will not work.
  6. Check the thermostat: Ensure that the thermostat is set to the appropriate temperature. If it is set too low, the freezer will not freeze properly.
  7. Check the power supply: Make sure the freezer is properly plugged in and that the outlet has power.
  8. Check the clicking sound: If the clicking sound is coming from the compressor, it could be the compressor's relay switch, which is responsible for turning the compressor on and off. This could be the issue and will need to be replaced.
Please note that if a compressor is a sealed unit and you're not able to charge it, it's best to contact the manufacturer or a professional for further assistance.
1/22/2023 3:10:23 PM • Haier... • Answered on Jan 22, 2023
My 18 cu haier refrigerator not getting electricity to bottom fan
If your 18 cubic foot Haier refrigerator is not getting electricity to the bottom fan, there could be a few different issues causing the problem. Here are a few things you can check:
  1. Check the power supply: Make sure the refrigerator is properly plugged in and that the outlet has power.
  2. Check the fan: Make sure the fan is not blocked or damaged and that it can turn freely.
  3. Check the fan motor: If the fan motor is not working properly, it could cause the fan not to turn on.
  4. Check the control board: If the above steps do not resolve the problem, the control board may be faulty and will need to be replaced.
  5. Check the wiring: Make sure all the wiring is properly connected and not loose.
  6. Check the thermostat: Ensure that the thermostat is set to the appropriate temperature. If it is set too high, the fan will not turn on.
  7. Check the compressor: Make sure the compressor is running and not too hot to the touch. If the compressor is not running or is hot, it may be faulty and will need to be replaced.
If you are not familiar with any of these steps or if the problem persists after trying these solutions, it's best to contact the manufacturer or a professional for further assistance.
1/22/2023 3:07:24 PM • Haier... • Answered on Jan 22, 2023
I have an Haier PRCS25TDAP Side-by-side refrigerator that won’t stop dinging. How can I stop it?
If your Haier PRCS25TDAP side-by-side refrigerator is dinging and you're unable to stop it, there could be a few different issues causing the problem. Here are a few things you can try to fix it:
  1. Check the door: Make sure all the doors are properly closed and aligned. If the door is not closed properly, the refrigerator will think it's open and will continue to ding.
  2. Check the door switch: Make sure the door switch is properly aligned and not damaged. The door switch is responsible for detecting when the door is open or closed and can cause the panel to malfunction if it is not working properly.
  3. Check the control board: If the above steps do not resolve the problem, the control board may be faulty and will need to be replaced.
  4. Check the settings: Make sure the temperature settings are correct and not accidentally changed.
  5. Check the ice maker: If the ice maker is not functioning properly, it could cause the refrigerator to ding.
  6. Check the water supply: If the water supply is turned off or clogged, the refrigerator will ding continuously.
  7. Check the water filter: If the water filter is clogged, the refrigerator will ding continuously.
1/22/2023 2:31:32 PM • Haier... • Answered on Jan 22, 2023
Kegerator. Is the compressor shot?
It's possible that the compressor in your kegerator is shot and will need to be replaced. However, there are a few other things you can check before determining that the compressor is the issue.
  1. Check the power supply: Make sure the kegerator is properly plugged in and that the outlet has power.
  2. Check the thermostat: Ensure that the thermostat is set to the appropriate temperature. If it is set too high, the compressor will not turn on.
  3. Check the compressor overload protector: The overload protector may have tripped, check to see if it is tripped and reset it if necessary.
  4. Check the compressor's capacitors: They could be damaged and need replacing.
  5. Check the evaporator fan motor: If the evaporator fan motor is not functioning properly, it could cause the compressor not to turn on.
  6. Check the 3 in 1 starter: Make sure the 3 in 1 starter is working properly, it could be defective.
  7. Check the wiring: Make sure all the wiring is properly connected and not loose.
If you have tried all above steps and the problem persists, it may be best to contact a professional or the manufacturer for further assistance. It could be the compressor, but it's better to confirm that before replacing it, as it's a costly repair.
1/22/2023 2:29:19 PM • Haier... • Answered on Jan 22, 2023
Model hrf15n3ags. How can I get electronic door panel to stop beeping and switching back and forth between 0 degrees and 37 degrees after the fridge door is opened?
If your Haier HRF15N3AGS refrigerator's electronic door panel is beeping and switching back and forth between 0 degrees and 37 degrees after the fridge door is opened, there could be a few different issues causing the problem. Here are a few things you can try to fix it:
  1. Check the door switch: Make sure the door switch is properly aligned and not damaged. The door switch is responsible for detecting when the door is open or closed and can cause the panel to malfunction if it is not working properly.
  2. Check the sensor: Make sure the temperature sensor is properly placed and not damaged. The sensor is responsible for detecting the temperature inside the refrigerator and can cause the panel to malfunction if it is not working properly.
  4. Check the power supply: Make sure the fridge is properly plugged in and that the outlet has power.
  5. Check the settings: Make sure the temperature settings are correct and not accidentally changed.
1/22/2023 2:27:35 PM • Haier... • Answered on Jan 22, 2023
I have a Haier HTE14WAAWW-02 refrigerator the freezer and refrigerator is not working neither getting cold the fan does not come on gets hot to touch by the compressor i hear a click every few minutes
It sounds like your Haier refrigerator is having an issue with the compressor and cooling system. Here are a few things you can check:
  1. Check the thermostat setting: Ensure that the thermostat is set to the appropriate temperature. If it is set too low, the fridge will not cool properly.
  2. Check the compressor: Make sure the compressor is running and not too hot to the touch. If the compressor is not running or is hot, it may be faulty and will need to be replaced.
  5. Check the evaporator fan motor: If the evaporator fan motor is not functioning properly, it could cause the refrigerator not to cool.
  6. Check the defrost system: If the defrost system is not working properly, the evaporator coils will frost over and the refrigeration will not work.
  7. Check the power supply: Make sure the fridge is properly plugged in and that the outlet has power.
1/22/2023 2:26:05 PM • Haier... • Answered on Jan 22, 2023
Haier refrigerator hrf-628af6 ice tray stuck cant release from fridge
If the ice tray in your Haier refrigerator is stuck and you're unable to release it from the fridge, there could be a few different issues causing the problem. Here are a few things you can try to fix it:
  1. Check the ice maker arm: Make sure the ice maker arm is not stuck or broken. If it is, it will need to be repaired or replaced.
  2. Check the ice maker mechanism: Make sure the ice maker mechanism is not jammed. If it is, try to unjam it by gently pushing or pulling on the tray.
  3. Check the temperature: Make sure the freezer temperature is cold enough for the ice to freeze. If the temperature is too warm, the ice will not freeze properly and may become stuck in the tray.
  4. Check the water supply: Make sure the water supply to the fridge is turned on and that the water supply valve is not closed or clogged.
  5. Check the water filter: Make sure the water filter is not clogged. If the filter is dirty, replace it with a new one.
  6. Gently try to move the ice tray by pushing or pulling, if it still won't come loose, it may be best to contact the manufacturer or a professional for further assistance.
Please note that some models of the refrigerator have a release lever, check the owner's manual to locate it.
1/22/2023 2:24:16 PM • Haier... • Answered on Jan 22, 2023
Haier HVW18A Wine Cooler Logo
14 questions posted
Top Haier Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
vince
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Haier Refrigerators
  • Haier Refrigerators
Most Popular Question
haier hvw18 wine cellar top fan
  • Refrigerators
