Question about Haier Refrigerators
I have an Haier PRCS25TDAP Side-by-side refrigerator that won’t stop dinging. How can I stop it?
Posted by Kim Hayworth on
5 Related Answers
e-Guru
e-Guru
  • 3917 Answers
SOURCE: Our Haier refrigerator is leaking water below the
The reason for your fridge to leak water on floor sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a boaster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear.
Thank you for contacting Fixya.com
Posted on Aug 12, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: JCD2389G Side by Side Refrigerator: REFRIGERATOR SIDE OF SIDE BY SIDE REFRIGERATOR NOT...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 24, 2010
bobicehouse
Robert Moller
  • 1524 Answers
SOURCE: my refrigerator side has stopped cooling. Freezer
Defrost problem.
Posted on Jun 03, 2010
machinetech7
Jason Kennidy
  • 1344 Answers
SOURCE: Frigidaire side by side freezes in the Refrigerator side
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Posted on May 17, 2012
Testimonial: "thinks alot, after 24hrs it staying at 39f so its working now i don't know why but she all fixed the only thing i did was turn it off for a min and turn it back on. "
Anupam Patel
SOURCE: GE TFX24E side by side refrigerator, ice maker
Hi, I have a GE TFX24E refrigerator. The ice maker is not filling with water. I replaced teh water valve with no joy. If I pour a cup of water into the dispenser the ice maker will freeze and harvest the ice. Any ideas? Is there a replaceable water fill sensor?
Posted on Jul 05, 2012
Not cooling and led blinking from top to bottom
Your refrigerator is in "Cooling Off" mode, or sometimes called "Store Display Mode", which basically allows everything in the fridge to function except for the Cooling system. Press and hold down the "Lighting" and "Freezer" buttons for 5 seconds until you hear the "Ding Ding". Your 'fridge will be working again.
Feb 26, 2014 | Samsung RS261MDPN Side By Side...
Haier aes44w stopped cooling and makes clicking noise
change the ptc overload/relay on the side of the compressor,this unplugs off the side of the compressor and its function is to aid in starting and run of the compreessor
Aug 12, 2012 | Haier Refrigerators
Refrigerator does not maintain 37 degrees
i have seen this problem before its the control board in the back the board is about 150 dollars and it goes every DING DING 5 years lol horrible design of the one that comes on the fridge every ge side by side has this problem  its very easy to replace but have to "ground" yourself before you touch the new control board meaning rub you hands on plumbing pipes, not pvc or copper
good luck if you got questoins let me know
Jun 08, 2009 | GE PSS25NGM Side by Side Refrigerator
Keep switching between jet and express. making ding ding ding noise.
Please explain what your meaning of jet and express so I can help you better. LG refrigerators are hard to get parts for. But, I can help you. So I can help and will you look for the model listed above your post. Please confirm the model number, this is very important, Thanks, Sea Breeze
May 02, 2009 | LG LRSC26930 Side by Side Refrigerator
How does one remove dings in stainless steel doorskin for frig
Dry ice set in the spot. Means getting the spot horizontal. Don't touch the ice and it don't take much. BE CAREFUL. If this is help, please post as such.
Mar 30, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Door alarm continually dings
This model and the Kenmore equivalent still have lots of bugs... I've replaced the microprocessor board on mine twice -- thankfully under warranty -- costs in excess of $600,,,
my suggestions are:  1)  verify that the two door switches (at top seal area one each side) appear to be working OK -- push them w/ your finger and see if the the refrigerator light goes off  2)  either pull the plug on the refrigerator or open the breaker feeding it -- count 30 seconds and put power back to it -- it's a computer, every so often you have to "reboot" it because it it loses its mind now and then...  3)  you should be able to push (I think the left most touch pad) the touch pad key under the alarm to shut it off....  4) if all else fails, ??? can you afford not to replace it ???
Jul 27, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Refrigerators Logo
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
