Question about Haier Refrigerators
Kegerator. Is the compressor shot?
Installed a Supco 3 in 1 starter. Still will not start.
Posted by Len Dummer on
5 Related Answers
peyton32034
peyton thompson
  • 410 Answers
SOURCE: Need to Install a Supco 3 n 1 start capacitor
3 in 1 starters like the supco that you have pictured can and will cause premature failure of your compressor. newer compressors are not designed to handle the start up current the 3-n-1 provides. I reccomend replaing wiht an original oem part the part number is 8201786. If you still want to use the hard start use the 410 model obviously hook up the red white and blak wires to the compressor the 2 left over leads will connect to the 2 original wires that come in to the compressor I beleive they are red and white. polarity does not matter. good luck Peyton
Posted on Feb 28, 2009
Maytag317
Victor
  • 1136 Answers
SOURCE: Compressor problem, installing the Supco 3-in-1 Relay
Hi, If the 3 posts are top center and bottom right left, the black wire goes top the top center post. The red wire will go to the bottom right and the white goes to bottom left.
If the posts are bottom center and top right left, the black goes on bottom center and the red goes top left. The white goes top right.
If you do not see a capacitor, disregaurd the wires in the 3-1
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 02, 2009
Dennis Boxerman
  • 1303 Answers
SOURCE: I have a BM23 Beverage-Air
electrician do one thing, electricity. If the unit cools, the compressor is running. a power outage should not put the compressor in a "Weaken" state. I would check the starting components. don't overlook your surge protector causing a voltage drop. try running the unit without the protector.
let me know if I can be of any further help.
Posted on Jul 11, 2010
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: Have 5 year old HAIER
You shouldn't need a hard start relay for one just 5 years old. The compressor and complete sealed system is usually covered by a 5 year warranty. If you hear no click from the compressor starter relay you need to verify that you're getting power to it when you plug it in. You may just need to replace the starter relay and not the kit. If your starter looks or smells burnt or if it rattles when you shake it it's bad.
Posted on Mar 11, 2011
mike cooper
  • 884 Answers
SOURCE: Supco wiring an old freezer. Orange wire?
Was the orange wire on a switched live on the old compressor connections? It may come on when the compressor goes off in that case. If not, recheck the schematic for the other end of the heater. If it has a neutral, join the orange to the live feed to the supco. If it has a live, leave the orange on the neutral of the supco.
Posted on Apr 21, 2012
Testimonial: "Thank you!"
Emerson model#CR519B. The unit just stopped working. If plugged in a motor runs for about 8 seconds and clicks off; about a minute later it repeats. Help
I had the same problem with a small wine cooler. It happened to me twice in 6 years. Both times I had to replace the starter relay.
I couldn't find any repair facilities willing to work on these small wine coolers or refrigerators, probably because the bill would be more than the used fridge is worth. If you feel confident around a volt/ohm meter and electricity, you could learn how to test this and maybe fix it yourself.
You shouldn't do any of this if you aren't familiar with using a Volt/Ohm meter and can safely and confidently work around electricity.:
  1. Unplug the fridge
  2. I first tested the compressor with an Ohm Meter (see how with youtube video below or by reading how at Davesrepair.com). It was good, but it kept starting and stopping within a few seconds.
  3. Basically my starter capacitor/relay wasn't working. It supplies temporary starting voltage to the starter relay in the compressor, then cuts off to allow the motor to run.
  4. I bought a Supco 3-in-1 on Amazon for less than $13 and hooked it up according to the supplied instructions. It lasted about 3 years.
Of course, the factory recommended repair is to buy the original replacement relay, but it will be more costly and harder to find.
I bought a Supco 3 in 1 Hard Start relay sized for the HP on my compressor. Mine was the Supco RCO810 (see link below).
NOTE: Before I replaced the starter relay and overload protection with a Supco 3 in 1, I learned how to test the compressor with a Volt/Ohm meter. If you don't have a meter, you can buy them online or inexpensive to free with a coupon at Harbor Freight.
Feb 15, 2015 | Emerson Refrigerators
Traulsen refrigerator fans power up but not compressor after 12 month storage
either the tstat or the starter pack is bad - I'd start off by replacing the starter pack with a all in one type. 1/3 horse size by supco. should have it at your local parts store.
Jan 04, 2015 | Traulsen Refrigerators
TDD 2 Kegerator clicking and not cooling?
It's extremely rare that the compressor will be any good. Usually replacing the start relay does nothing on these small units. If you know how to use a multi-meter and are any good at wiring the cheapest way to go is to get what is called a 3-in-1 start kit at a HVAC wholesaler. You need to know the model of the compressor and/or the horsepower to get the right one. I would recommend getting a service tech to look it over though. Most likely the compressor is locked up.
Nov 16, 2012 | True Direct Draw Systems: Kegerator TDD-2
Apr 21, 2012 | Refrigerators
Looking to install a supco 3 n 1... any advice? good idea?
I INSTALLED ON THIS LITTLE FREEZER. HERE IS THE VIDEO. BUT IT DID NOT START COMPRESSOR - SO COMPRESSOR IS BAD,
Feb 28, 2011 | KitchenAid Superba Architect KSCS25INSS...
Not cooling either side. compressor not running
Most likely you will need a Supco 3 in 1. It's a capasitor, relay and overload assy. You can buy the exact replacment at http://www.partselect.com/MultiModels.aspx?ModelNum=mzd2766&searchTerm=img_53200&RefineSearch=0&imgMfg=Maytag parts #4 and #6. They cost a total of $83.35 plus shipping. If you go with a Supco 3 in 1 like I have suggested you can find it at http://www.appliancepartsonline.net/index.php?target=products&product_id=207 for $21.95. It's very easy to install. It only has 3 wires that go on the compressor and two that you connect the power to. The instruction are on the part and very easy to understand. The 3 in 1 is also a much stronger part and will out last the factory part by a long shot. Good luck.
Dec 19, 2009 | Maytag MZD2766GES Side by Side...
Compressor stops running and keeps cycling every few minutes. It buzzes as if the compressor is gone. the compressor is hot. If the thermostat is turned to off for 6 to 8 hours and then turned back on the...
you can replace the relay with a 3 in 1 made by supco. i generally just use a supco 0410.
www.supco.com
it is a start relay, overload, and start capacitor all in one. works great for residential systems.
Nov 06, 2009 | Frigidaire FRS3R5EMB Side by Side...
My bev air bm23 kegerator wont cool. the fan works like it is suppose to inside 24/7. The fan outside works as well. There is a hhhmmm sound and then a click. It thought it was the compressor so i took the...
Yes replacing the relay may fix the problem. You want to replace all the start parts. Overload, relay, and capacitor if one is present. Your unit is probably 1/3 horse power or less. You may be able to install a universal 3N1 starter from Supco, rated at 1/4 -1/3 H.P. If new start gear does not fix the problem you may need a new compressor.
Nov 05, 2009 | Beverage-Air BM23
The compressor starts, (or tries)for ~ 3 seconds, stops. retires ~ 15 seconds.
You either have a problem with your compressor start relay/overload assembly.......or you have a bad compressor. You would need the model/serial number for the correct part. If the unit is out of warranty, a 3 in 1 hard start kit (Supco URCO41) can be installed. Disconnect unit from power prior to attempting repair, and follow the instructions with the part.
If the product is under 5 years, the compressor may still be under manufactures warranty. In that case attempting a repair would void the warranty.
Jun 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Feb 28, 2009 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
330 people viewed this question
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
