20 Most Recent
Bazooka EL260 Car Audio Amplifier Questions & Answers
No Power
It appears that there may be an open trace inside the amp. This assumes that the ground connection between the amplifier and the vehicle is intact.
Don't allow the RCAs to contact anything other than the RCA jacks of the amp. Some head units are easily damaged when the RCA shield contacts a power source.
The amplifier will need to be repaired. It's a simple repair and shouldn't be expensive.
Let me know if you have any other questions.
Bt8250d is cutting out
Loose connection or your power cable and earth cable to your amp are not a heavy enough gauge.
Speaker Fried, is my Amp toast too?
You are sending TOO much power to the speakers, Replace the speakers and then get a much smaller amp that is within the ratings of the speakers. ACTUALLY you should get an amp that is aboout 1/2 the total rating of the speakers.
You should ALSO procure a sound meter to verify the sound level is within safe limits. If you insist upon abusing your ears with too high a sound pressure, be ready to buy hearing aids at a VERY young age.
You also need to know that the enclosure of the speaker plays a part in keeping the speaker from tearing itself to pieces.
MANY of the auto sound system installers are hacks that don't do it right and you see what happens to your expensive equipment!
Using even a Radio Shack sound meter properly will protect your preciuos hearing for later life.
Bazooka amp
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following. I'll assume that you've checked the amplifier's on-board fuses.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it remains in protect mode, the amp almost certainly has shorted output transistors and will need to be repaired.
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
