Car Audio & Video Logo
Question about Bazooka Car Audio & Video
Bt8250d is cutting out
Sub works when you start up car after a while it stops working it works when accelerating or egine rpms are up stops working while at idle
Anthony Carman
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 126 Answers
Loose connection or your power cable and earth cable to your amp are not a heavy enough gauge.
Posted on Nov 30, 2014
2 Related Answers
Anonymous
  • 68 Answers
SOURCE: my sub just stopped working.
because of plug lost
Posted on Sep 10, 2009
Anonymous
  • 492 Answers
SOURCE: My sub keeps cutting in
Your amp may be going into protection or you might have a loose connection. Start with your ground wire to make sure it's a good ground. The check all the other wiring. Hope this helps.
Posted on Aug 26, 2011
Why does my 1990 Daihatsu charade want to cut out and stall when giving throttle unless it's in high rpms it doesn't want to go we've replaced the fuel pump and filter could it be the injectors?
Daihatsu Charade low idle problems Questions & Answers ...
www.fixya.com > ... > low idle problems > Cars & Trucks > Daihatsu
Daihatsu Charade cars & trucks low idle problems questions and answers. ... but idles unevenly with foot on accelerator. does not want to accelerate. please . ... problem daihatsu cherade 1991. when the airconditioner is on the car stalls when changing down to a lower . ... 1990 daihatsu applause 101a 1.6lt 5spd manual.
Daihatsu Charade car keeps cutting out when stop ... - Fixya
www.fixya.com > ... > Cars & Trucks > Daihatsu
Daihatsu Charade cars & trucks car keeps cutting out when stop questions and answers. ... 1997 Daihatsu Charade CS G203 1.5i manual stalling when warm ... gear) while accelerating or when coming to a stop and you take it out of gear and ... 1990daihatsu applause 101a 1.6lt 5spd manual car starts normaly. when auto ...
1helpful
Have an fx45.Should the tach read 25-3000 ROMs when moving at 75mph? Auto tranny seems like it should be in higher gear.
there is not info to be able to give a definite answer
to work it out
you have top know the diff ratio, wheel tyre circumference to be able to work from rpms of the engine to road speed
However as a pointer, most cars will be around 3200 rpms at 60mph as this will be direct drive and od causes a drop in rpms
Being an automatic find yourself a good section of low traffic road and start from stop slowly increase the rpms and watch the rpms. keeping the accelerator steady you will see when the auto changes by a drop in rpms. slowly increase road sped until you see the next drop in rpms and so on. Over drive normally comes in around 55 mph or around 3000rpms
I would think that it is working because 3500rpms at 75mph is reasonable rpms to be expected. If it wasn't working I would expect the rpms to be around 3800 to 4000.at 75mph
Will not excelerate past 4000 rpm
IF you have a carby then take it apart and clean it out as all the throats are not working properly including the accelerator pump.
Engine starts cutting out when accellerating to get up to speed or to pass someone.
Try several things...
Fuel injector cleaner
New fuel filters
Check for vacuum leaks
New spark plugs and wires
Car stalls when stopped, cuts out when accelerating to HWY spds.
You could have a bad or intermittent fuel pump. Not a cheap thing to have.
An OBD 2 scanner can read fuel pressure on the drive to see if your fuel pressure drops off at odd times to confirm. It can also tell if there are transcient vacuum leaks at idle which the engines idle air control cant compensate for.
Do the plugs, wires and cap too.
2answers
RPMs drop
spark pug gaps are critically important & can even stop a car from starting! start there!
then reset the timing!
computorised cars should be banned! lol
Subs dont beat like they should
you've spent alot of money on **** by the sounds of it!!. you should only ever run multiple subs the same brand, power and resistance you can just connect any old subs to a system you need to wire them depending on the load that the amp needs to see. first thing is to try the amp/s on a individual sub to check your amps still work once done check the subs 1 by 1.
Wont start
the car flood itself when you remeve the plug you cut the gas pump that why our fuel gauge stop working you probably got a bad temperature sensor take a look at the sensor thank you
pierre
Top Bazooka Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Bazooka Car Audio and Video Expert? Answer questions, earn points and help others
