Car Audio & Video Logo
Question about Bazooka Car Audio & Video
Speaker Fried, is my Amp toast too?
Yesterday i was driving to my buddy's house when my sub just stopped working. i get to his house take a look and the wire inside the speaker box connecting the input to the speaker was completely fried. i replaced this wire to find my speaker was blown... but still works to some point. but my Real problem is that if i use this speaker and turn the sound up to loud it click off my amp. the blue logo turn read and all sound coming form my amp stops.
My question is, is my Amp toast too? or is this just some type of safety to prevent damage to the amp because my speaker isn't working properly
Posted by deadkipper on
Fred Yearian
  • 5,603 Answers
You are sending TOO much power to the speakers, Replace the speakers and then get a much smaller amp that is within the ratings of the speakers. ACTUALLY you should get an amp that is aboout 1/2 the total rating of the speakers.
You should ALSO procure a sound meter to verify the sound level is within safe limits. If you insist upon abusing your ears with too high a sound pressure, be ready to buy hearing aids at a VERY young age.
You also need to know that the enclosure of the speaker plays a part in keeping the speaker from tearing itself to pieces.
MANY of the auto sound system installers are hacks that don't do it right and you see what happens to your expensive equipment!
Using even a Radio Shack sound meter properly will protect your preciuos hearing for later life.
Posted on Dec 22, 2009
2answers
Ok I just bought a used fosgate amp belive its a T10001b could be wrong its big has fan 3 led lights and some pioneer premier 10 flat subs think there 4ohm. I bought a brand new amp install kit 6gauge...
eyp, most of the time speaker connections blow and fuses wont stop that from happening. They are there to stop the mainboard from frying and not working at all. try running rca splitters to the operational side of the amp. run the sub on 1 channel. you will start hearing a difference but both sides will work. if not, run the splitters from the head unit and bridging it. these are the cheapest solution i could provide
1helpful
Left positive speaker input stopped working
try swapping over the rcas for instance if black is in r and red is in l then swap them so red is r and black is l
if that doesnt work try swapping the subs over to as you may have a faulty sub. if that doesnt work then check the fuses on the amp
still no joy then i would suggest taking your amp to your local car audio dealer and getting them to have a look at it
Hope this helps if so please dont forget to rate
best wishes
Upfront Audio
2helpful
3answers
Fried electronics in KLH ASW10-120B subwoofer
It is a 4 ohm nominal impedance woofer. If you put a new woofer in, it will last maybe half an hour and then fry/melt. The problem is the amp, not the woofer. Throw the amp out and use the box as a passive sub. Get a 100 hz sub crossover.
3answers
Kicker 750.1 Amp wont play music
it is probably the rca inputs on the amp may have fried. was your cd decked turned up loudly before the power went out? did any wires accidently touch each other? If had worked fine and then suddenly stopped, than either a wire came loose or the inputs fried. try using different cables and I also suggest disconnecting power for 24 hours and then reconnect. If the green light is on then it is getting power and the problem is in the rca cables or the inputs
Subwoofer stop working
push down on the speaker, does it make a ruff nosie? if so the speakers voice coil is blowin. did ya check the amp to the subs?
could be a lot of things . check the amp make sure it has power,
do u have an in line fuse? if so check that ,to make sure it aint blowin
Minimal sound from subwoofer
MAKE SHURE YOU HAVE TOLD THE AMP YOU HAVE A SUB IN THE SET UP MENU UNDER SPEAKER SETTINGS.
IFF YOU ARE USEING SMALL SPEAKERS THEN SET THIS IN THE MENU AND OUT PUT BASS 2 SUB ONLY ,SET XOVER ON AMP IFF U CAN 2 120HTZ, ALSO CHECK THAT YOU HAVE THE SUB CABLE PLUGED INTO SUB OUT ON BACK OF YOUR AMP ,AND NOT THE 6 CHANNEL INPUT.
HOPE THIS HELPS.
CABLE GUY.
Jbl psw1000 no power
Have you checked all fuses. There might be 2 - one for the input and one specifically for the amp section...
Check to see if the speaker is fried. Remove the grill then place your fingers as evenly as you can aa couple of inches away from the cone. Press gently and listen. There should be no scrating sounds at all. If you hear this, first try repositioning your fingers. If it persists your speaker is fried. This is caused by a few reasons. Amp failed and took speaker with it. Or a large signal was inputted which causes the amp to hold its max power for a longer period of time (amplified signal is no longer a sine wave but a sqare wave).
Otherwise, unless you know what you are doing with AC (house power) I don't suggest you go poking around-you need at least a volt meter to start testing
Problem in ppi pcx-2400
Check the amplifiers fuses. Some amps have speaker fuses that leave the LED on if blown. Check for continuity on the voice coils of both subs. Check for 12 volts on the remote turn on line from your receiver. If all of the above are good, the amp is probably toast.
Red light
Have you disconnected the wire from the speaker?? and the amp?? Maybe the wire is pinched as I suggested?? If not then yes I would sy the peaker could be bad or the amp output on that channelis fried.
Top Bazooka Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Bazooka Car Audio and Video Expert? Answer questions, earn points and help others
