20 Most Recent
Philips 47PFL7422D/37 Television Questions & Answers
Phillips tv has no power
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
6/25/2017 1:38:54 PM •
Philips...
Answered
on Jun 25, 2017
Half of my 47" LCD Phillips screen fades from normal to dark. Any thoughts?
If it\'s a backlight issue one section will be dim and will fade darker or lighter to the other section. It is not a hard on/off line. So if it does fade to dark on one side I would suspect either a faulty backlight bulb (non-replaceable) or a failing backlight inverter (can be replaced.)
1/7/2014 7:44:18 PM •
Philips...
Answered
on Jan 07, 2014
