20 Most Recent
Dell Dimension 8300 PC Desktop Questions & Answers
PC sometimes shuts off for no reason
When it does shut off, can you start it up right away or does it take some time before it starts up? if yes, it is the CPU that heats up prompting the system to shut off.
However, if no, it could be a loose connection somewhere. Please advise....
Ack graphics card wont fit in any input slots
the adapter u are using is pci express and the dell dimension 9100 are not compatible.. try returning it for either a pci (usually the white slot) or AGP which in most cases is brown.. the AGP will be your best performance.. if return is not an option.. then it seems that a new pc is in your best interest.
On my DELL Deminsion E110 the video downloads are sporadic and jerky, but audio is good
Audio is easy...requires little ram to operate. Video today needs 2 GIGABITS or more for VIDEO. A lot depends in the Motherboard Processor also. If it is old, the main processor is no doubt slow. High speed internet is faster than some computer speeds and thus the computer is trying to buffer (catch up) which causes means conditions to occur. Lag time with Video is one problem.
Windows operating system is another. Win 8-10 are ok, but older OS's are slow. THEN we have a Video Card problem. Old cards require new drivers to keep up with changes. Some old Video is slow because the VIDEO RAM is too slow and old. Solution = a New 2018 Computer
When I turn on my Dell DM061 (Windows Vista)
all these symptoms can be from ram stick fault, graphic card or graphic section of the mother board or a failing hard drive
you will probably have to have it properly diagnosed by a computer repair shop to find out exactly the failing component
Restoring my computer dell dimension 5150to factory setting
1 Turn on the computer.
2 When the Dell splash screen appears during the computer startup process, press and hold <Ctrl> and then press <F11>. Then, release both keys at the same time.
3 In the Dell PC Restore by Symantec window, click Restore. Alternatively, press <Tab> to highlightRestore, and then press <Enter>.
4 When a warning message appears stating that all data will be lost, click Confirm, or press <Tab> to highlight Confirm and then press <Enter>.
The Progress window will appear. Once the restore process starts, Dell PC Restore by Symantec usually takes about 8 to 10 minutes to finish.
When the restore process is complete, the following message will appear:
The system recovery process was successful.
Lost emails
Likley still on your email providers 'server' .. Log-in using a web browser (Firefox whatever)
If you can't find them ij the 'In-box', look in the 'deleted' folder
Dell 4600
When editing the BIOS if you go into the BOOT ORDER menu, it is possible that the network card is not showing as an option. In order to get this option to display, go into the "integrated devices (legacyselect options)" and then select the network interface controller. Edit that even if it is On and change it to On w/PXE. After saving the changes to the BIOS, you need to power the computer off then on and then go into BIOS again, and the "integrated NIC" option should be available in the BOOT ORDER menu. Set this to be the first boot device in order to use PXE.
Won't read my cd
Only CD is not reading or DVDs also not reading?
In any case your dvd drive is not working.
If you are familiar how to open the drive open it and clean the lens
Boot Dell Dimension computer Safe Mode
Immediately, start pressing the F8 key once a second until the Advanced Boot Menu appears. If the computer starts up into Windows, turn the computer off and try again. Press the Up Arrow or Down Arrow key to highlight Safe Mode with Networking, then press Enter
