Had my RAM increased from 512 mb to 1.25 gb by the GEEK SQUAD. It improved the speed for about 3 days. However, for the last 2 days all video downloads (mostly YOUTUBE stuff is sporadic and jerky. However all the audio is just fine. It's as if the video is trying to catch up with the audio.
Audio is easy...requires little ram to operate. Video today needs 2 GIGABITS or more for VIDEO. A lot depends in the Motherboard Processor also. If it is old, the main processor is no doubt slow. High speed internet is faster than some computer speeds and thus the computer is trying to buffer (catch up) which causes means conditions to occur. Lag time with Video is one problem.
Windows operating system is another. Win 8-10 are ok, but older OS's are slow. THEN we have a Video Card problem. Old cards require new drivers to keep up with changes. Some old Video is slow because the VIDEO RAM is too slow and old. Solution = a New 2018 Computer
SOURCE: My computer shuts down after 3 secs
Try to separate the power cord of your monitor from your system or maybe if your using UPS(uninterrupted power supply) directly plug the UPS to the wall outlet. either you can use pretty voltage regulator to the regulate the AC power.
if not solve the problem try to examine the your system power supply.
SOURCE: Video card
Hi, Yosemic
Happy Holidays,
Sometimes is difficult to accept the reality of technology, but is happend, there is no 512 RAM video for this particular PC, but you can found for 256 ram, yet from Nvidia or Radeon taste.
PCI-E is eating the market.
(time to change your MOBO)
SOURCE: my hardware upgrade
basically just buy agp 64mb up to xx mb. its kind of plug and play. Just insert your new Video card to the agp slot make sure you have high resolution monitor to support your new video card. You dont need to upgrade the sound card its best if you have good quality speakers
SOURCE: celeron d ram
you will have to find out what type of ram it is DDR, DDR2, DDR3, and how many sockets the motherboard has.
What Model is this computer or what is the mother board model? then we can find more out.
SOURCE: upgrading ram in a dell 5150 do I need to install
you have 4 memory connectors. the maximum memory the computer supports is 4 GB. it is recomended that you install in pairs, for some reasons, but i have installed and i have seen it doesnot matter at all. you can go ahead and install the memory for whatever size on the computer. make sure the bus speed should be either 400 or 533 MHZ. and yoou never explained the error message. when you upgrade the ram you will get a message the system memory has changed press f1 to continue or f2 for setup just press f1. if the error message is in windows after you click on your name it has nothing to do with your memory. if its before that. than try to reseat the memory. installing memory in non pairs doesnot cause any problem most of the time. explain the error message only than i can guide you furthur.
