20 Most Recent
Parrot Mki9200 Bluetooth Car Kit Alfa Without Bose Questions & Answers
Reset memory
if your memory is full you might have parrot kit wired wrong !!
check kit says goodbye when you switch ignition off , if it doesn`t then you have the power and ignition wire connected the wrong way . easiest way to fix is swopping over the wires where the inline fuses are
Why has my parrot 3100 stoped ringing when someone phones me
This may be one of two issues: Check to make sure that the fuse on the battery line is still good and the battery line connections are still good. Check to make sure that the battery line is in fact connected to the battery and not also tied in with the ignition line.
Adult parrot inst. how to use remote control.
WOW, just wow. I have seen some weird questions but this is a first. You want to teach an adult parrot to use a remote control if I am getting this correctly. All I can tell you is good luck - some adult humans can't handle this.
