20 Most Recent Parrot Ck3200ls Lcd Color Display For Bluetooth Phones Questions & Answers
Hi.
The problem is due to an issue with Windows Mobile 6. Try updating Windows mobile on the parrot. Eventually install the latest 6.xx release. If that does not help try updating the Blackberry OS. Also upgrade the parrot firmware.
Before that you can also try upgrading the Parrot's firmware with the laptop through bluetooth connection while in the car. Some user reported that this method may fix several problems affecting bluetooth connection between BB and Parrot.
Parrot Ck3200ls... | Answered on Jan 21, 2011
You can download the user manual for this unit from this link , just click HERE and also from HERE.
Parrot Ck3200ls... | Answered on Oct 06, 2010
Maybe cause you do not have the auto synchro to the phone? does it allow it?
Without the mobile, almost impossible to make a diagnose. But mainly either cause of a button which is not working, but you should have at the minimum, settings and the top menu. Hear the sound on the speaker.
If not, that could simply be cause of a trouble.
Parrot Ck3200ls... | Answered on Mar 18, 2010
yes you will need a (sot112) to link through your radio
Parrot Ck3200ls... | Answered on Mar 03, 2010
What type fo car do you have beacuse if you car does not have iso connectors you will need an SOT adaptor, this will allow the audio to come through the car speakers.
Parrot Ck3200ls... | Answered on Feb 08, 2010
make sure all contacts are on the phone memory not sim card as the kit cat read simcard,or else send contacts to kit via bluwtooth
Parrot Ck3200ls... | Answered on Jan 17, 2010
Go to parrot.com and contact one of their accredited installers. they will do it properly.
Parrot Ck3200ls... | Answered on Jan 11, 2010
Hi, no you cant receive and manage text from this handsfree, the signal strengh is displayed if the phone allows it, some phones will display battery and signal, some only battery etc.
Hope that helps
Parrot Ck3200ls... | Answered on Nov 23, 2009
The parrot 3200 has its own pairing codes, go into settings then pair with phone, other phones and on the screen the kit will display a pass code. Search from the phone for the kit, add the parrot 3200ls and enter the pin that is on the screen. If you get it wrong start again it will be a different code tho. you dont have to remember it.
From the kit go to SETTINGS
** select CONTACTS MANAGEMENT
** select RECEIVE CONTACTS
* From the phone select OPTIONS
* select BLUETOOTH
* select PARROT 3200LS
* select TRANSFER CONTACTS
Dan.
Parrot Ck3200ls... | Answered on Oct 10, 2009
With most Bluetooth objects, the code is going to be 0000. If you're not able to get to the code after the Parrot recognizes the voyager, try removing the battery while the phone is still on. Replace the battery, power on, and try again.
Parrot Ck3200ls... | Answered on Jun 29, 2009
yes you can just pair the second phone up . You can't use them at the same time though.
Parrot Ck3200ls... | Answered on Oct 17, 2008
I recently found out all you have to do is reset the blackberry. Remove the battery and let it re boot. Problem resolved.
Parrot Ck3200ls... | Answered on Aug 12, 2008
To update your Parrot CK3100, visit the support page at Parrot.com to check whether a new update is available.
Parrot Cell... | Answered on Apr 02, 2019
Have you tried pressing the 3 buttons?
Hard reset the CK 3100 by pressing all three buttons for two seconds and then pressing them a second time, a warning should indicate that you are about to reset all settings
Parrot Cell... | Answered on Mar 27, 2019
Parrot Ck3200ls Lcd Color Display For Bluetooth Phones Logo
27 questions posted
Top Parrot Cell Phones Experts
donny ardalando
donny ardalando
ray gallant
ray gallant
Marvin
Marvin
Are you a Parrot Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Parrot Cell Phones
  • Parrot Cell Phones
Most Popular Question
using 2 cell phones
  • Cell Phones
