Question about Parrot Cell Phones
My iPhone XR will not stay connected to my parrot 3100 every time I turn the engine off I have to reconnect it again and the memory says its full
Posted by Keith Daivd Driscoll on
5 Related Answers
Anonymous
SOURCE: parrot ck 3100 - Memory Full
How do you restore factory settings?
Posted on Jun 18, 2008
Anonymous
  • 5 Answers
SOURCE: Unable to connect my iphone 3gs to the Parrot CK3000 Evolution.
You need to reset the Parrot first.
Hold down red and green buttons together until she tells you that the memory is being cleared. Then she will prompt you to pair your phone.
Then, and only then does the Parrot allow the iPhone to pair, and it will bring up the code prompt for you on the iPhone.
You won't find this written down anywhere on the Parrot site.
Posted on Jul 03, 2009
Anonymous
  • 14 Answers
SOURCE: iTunes cant connect/recognise my iPhone 3G
Hi Try and plug your iphone to another pc and see if the same problem is still there, if no problem is form your pc, other wise you are having a problem whit your iphone i would advise to send your iphone to repair to www.E-Repairs.co.uk
Posted on Aug 28, 2009
Anonymous
SOURCE: parrot 3100 pairing with blackberry 8310
You have too many phones paired in the Parrot. Delete some of the phones from your parrot and you will be fixed. I had same issue
Posted on Oct 02, 2009
Anonymous
  • 10515 Answers
SOURCE: Tried to pair a Samsung
You can link up to 10 devices on the Parrot MKi9200.
If you link an eleventh phone, the kit displays “memory full” You then have to delete one of the linked telephones. To do this:
1. Press the knob and select Settings > Bluetooth > Linked devices.
2. Select the telephone(s) that you no longer need.
3. Select Delete
Let me know if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 14, 2009
None of our iphones can detect the parrot 3100
https://discussions.apple.com/thread/4349029?start=495&tstart=0
the above thread has several suggestions for solutions. The most common that seems to work is a phone reset. Make sure you backup any data first though.
4helpful
2answers
My Parrot v5.25c tells me the memory is full when trying to connect to my Galaxy S3
Hey everyone,
I have had the same issue with my VW Polo Comfortline 2012, trying to connect the Parrot v5,25C to a iPhone 4S.
I turned the ignition on and my phone Bluetooth together. I then hit the volume(-) button first then the volume(+) on the steering wheel, this has to be done in sequence - then + about 5/6 times. The car kit then said phone memory being erased and BOOM ready to pair again :-)
Its all up and running now with the pass code 1234 entered on the phone for activation.
I hope this helps!!
5helpful
2answers
I have a parrot ck3100, it won't allow me to stay connected to it. message memory is full, however i've delated the memeory it is empty. when i turn my car off & start again i have to reconnect my...
The question is about the power supply. In some vehicle the 12 dc and the ignition are inverted. Then i will advising you to the power supply of the kit to inverse fuses between the red one 12dc and the orange 12volt ignition.
1helpful
The parrot comes up with memory full when I
try holding the 2 bottons in for 1 min to reset the kit, if this doesnt work it will have to be replaced
Tried to pair a Samsung Renown U810 to Parrot mki9200. Phone found Parrot device OK and paired but did not ask for PIN code. Parrot shortly displays "Memory Full" error & phone pairs up. In a few...
3. Select Delete
Hope i helped you.
Oct 14, 2009 • Cell Phones
57helpful
6answers
Pairing a Parrot CK3100 to Iphone 3GS
My iPhone 3G is now connected. Did 3 things:
1. Deleted every existing paired device on the Parrot CK3100.
2. Pressed all 3 buttons at once. Parrot CK3100 screen lit up and buttons lit up after about 5 secs. Turned car engine off. Parrot switched off. Turned car on again.
3. Went to settings, advanced settings, pair device (and also switched on iPhone bluetooth) and tapped Parrot CK3100 on the iPhone screen (which had now appeared) - phone connected.
After about a minute sync iPhone phonebook appeared on Parrot.
Hope this is helpful.
2answers
My kit will not allow me to pair a phone, it comes up memory full i have unpaired all phones, how do i clear the memory (Parrot 3100 to Samsung tocco)
Disconnecting your car battery would clear the memory but ideally you need to update the firmware of your car kit through a bluetooth connection, instructions and software to do this can be found at http://www.parrot.com/uk/support/downloads. You need the Parrot software update tool. Instructions to do this are at http://www.parrot.com/uk/support/downloads/texte_fck_2/image/ck3x00_update_procedure__en.pdf for XP or http://www.parrot.com/documents/en/support/parrotck3100-vistaupgradeprocedureeng.pdf for Vista. Hope this helps if you haven't figured this out for yourself already.
Memory full
I've just solved that very annoying 'memory full' problem. Just turn on the parrot device and press down the red and green button at the same time. The instructions were in the user guide but they were t the end and seemed to be for the Sony Ericsson only. I have a Blackberry curve. Anyway its all working now after a month trying to figure it out
2answers
Parrot ck 3100 - Memory Full
Try reseting it to the Factory default. it should solve the problem.
Cell Phones Logo
Top Parrot Cell Phones Experts
ray gallant
john h
Fred
Fred
Are you a Parrot Cell Phone Expert? Answer questions, earn points and help others
