20 Most Recent Lakewood HV-9/C Floor / Box Fan Questions & Answers
What type and size capacitor is required for the Lakewood desktop fan motor model HV-9 C?
way to go tom posted to HP Compac forum on computers I moved you and the OP out of computers that is why noboby can understand you, and then answer wrong. amazing no> and yes don;t come back. that is always a good idea (sarc off) what not ask Lakewood this, it is there fan, not ours, we dont make fans at fixya, not yet. maybe next week? there is no lack of hot air here, as is on all forums. my guess the motor start capacitor is bad. call lackwood and ask for that or schematic or BOM or parts list see what they say, many things now, are throw-away. with no support at all. ok I google for you and here the are, ask them, its there design. http://www.lakewoodeng.com/Category.aspx?cid=1066
7/31/2018 11:49:30 PM • Lakewood HV-9/C... • Answered on Jul 31, 2018
Fan started running real slow.
There is a motor capacitor on the fan that is probably going bad...in order to replace this capacitor, you will need to obtain the correct component either from the manufacturer or from an appliance parts center...be sure to hook it up the same way as the old one is hooked up..
12/25/2010 4:19:57 PM • Lakewood HV-9/C... • Answered on Dec 25, 2010
Any idea where I could get a replacement motor for a Lakewood model HV-18 fan? The motor is fried, sparks coming out when I turn it on.
Take the motor out and take to a local motors repair and rewinds shop. Drop it on the counter and say "can I have one of these please". It is just a motor, form size, voltage and speed. https://www.google.com/search?q=Lakewood+model+HV-18+parts ..
2/14/2024 6:21:34 AM • Lakewood Dryers • Answered on Feb 14, 2024
Where can I get a Lakewood box fan repaired
You could repair it yourself or take it to a local electrical store or a vacuum repair shop. They are just a box, a motor and a switch. https://www.google.com/search?q=lakewood+fan+repairs ..
9/24/2023 5:35:42 PM • Lakewood Dryers • Answered on Sep 24, 2023
Where can i get a lakewood fan motor for lakewood fan model number HV-18
you would have to go to a place that sells motors and get one by motor type, that than the appliance make and model. All electric motors are standard by size, voltage, speed and fixings. https://www.google.com/search?q=lakewood+hv+18+replacement+parts ...
7/1/2022 6:03:50 PM • Lakewood Dryers • Answered on Jul 01, 2022
Need replacenent AC motor 110V 60Hz 1.7amps
google it
9/14/2021 11:53:56 PM • Lakewood Dryers • Answered on Sep 14, 2021
Mains Cord for Lakewood fan model LBF 2010A
Nothing specific to that fan, but they are all standard types. Pick the one that fits https://www.google.com/search?q=power+cord+types ..
6/30/2021 3:25:45 AM • Lakewood Dryers • Answered on Jun 30, 2021
I am replacing the 4 position 3 speed rotary switch with knob on a Lakewood Kool Operator 20" floor fan. Do I just pull the wires out of the broken switch and push them into the new switch?
MANY OF THEM YOU NEED TO USE A PIN PICK TO RELEASE THE WIRE SLIDE IT ALONG THE WIRE WHERE IT ENTERS
11/8/2020 9:50:35 AM • Lakewood Dryers • Answered on Nov 08, 2020
1994 Kool Operator 20 floor fan. Is the white wire ever the HOT wire?
normally black hot white neutral green ground
9/16/2020 3:21:17 AM • Lakewood Dryers • Answered on Sep 16, 2020
Have a 196M 3spd/hi-velocity Lakewood fan mfd 10/02. Motor sparked, I think it is over,has been the best EVER! We have been using it for well over 15 yrs. Want to fix it. Where can I get a new motor?
Unlikely I would think, a new motor will be available considering how the motor is a major part of the construction and how quickly new models replace previous models in the typical fan line up, even in the heavy duty and industrial types. Many fans use a brush type motor and after extended use the brushes will need replacing - have you had the motor checked? It might just need new brushes. If all else fails, there are small companies all over the world offering to rewind burned out motors, some specialise in the repair and rewinding of small motors, mostly to keep cherished or special power tools alive.
4/20/2020 10:31:06 PM • Lakewood Dryers • Answered on Apr 20, 2020
Lakewood mini tower fan model mtf-15. The oscillating fan stopped oscillating. How do you repair it?
Whether the fan has a dedicated oscillation motor or is driven by an extended shaft from the main motor, there is usually a button or switch to disengage the oscillating function. If this no longer has any effect the only cure is to dismantle the machine until the fault is discovered and then if a repair is possible - repair it... Most domestic fans have no spare part support, mechanisms have a limited life and if "handyman" repairs aren't possible it is considered a throw-away item.
8/21/2019 6:45:29 PM • Lakewood Dryers • Answered on Aug 21, 2019
Is there a good way to slow down my Lakewood HV-18 fan? It has 3 speeds, all working, but even the low speed is too fast.
hello martin you can buy a dimmer to slow down your fan 800 watt at least
4/30/2019 3:18:21 AM • Lakewood Dryers • Answered on Apr 30, 2019
Lakewood HV-9/C Floor / Box Fan Logo
6 questions posted
Top Lakewood Dryers Experts
Jay Finke
Jay Finke
Larry Ng
Larry Ng
ADMIN Eric
ADMIN Eric
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
View Most Popular
Lakewood Dryers
  • Lakewood Dryers
Most Popular Question
type size capacitor required lakewood
  • Dryers
