20 Most Recent Lakewood HV-18 Floor / Box Fan Questions & Answers
blade pulls off... grab hold w 2 hands, pulling n wiggling with just enough force til it breaks free. Good Luck
Lakewood HV-18... | Answered on Dec 20, 2017
mcdevito75 here, If the fan is not too old I would figure yes, but a replacement motor will cost as a new fan, if not more, then you have to install and the blades are a presss fit to the motor.
Lakewood HV-18... | Answered on Sep 20, 2015
ok here is what I found....there should be screws on the outside rim where the two fan grates meet....then dust the innerds with a leaf blower or a rag, then use brake cleaner spray to soften the greasy dirt that formed, and again a rag to wipe away any residue....hope this works, it did for me
Lakewood HV-18... | Answered on Nov 16, 2013
I've had an 1887 since the 90s -- great fan. I have to say that FixinFax (Solution 1 above) probably didn't try to take his unit apart. My blade has stopped rotating several times over the years and I always got it going again by myself. I'm no whiz, just your average amateur handyman. In fact I am fixing the motherbleeper right now because in a week where the heat is 100 degrees it chose to slow down and stop.
Eventually it sucks enough dust into the axle housing so you have to take the motor mechanism apart and clean it. It's not terribly complicated, but you have to note how the electrical and mechanical parts go back together before disassembling. It's a little tricky to get all the housing parts to line up level again, you may have to try a couple times till the blade rotates freely. Wipe out all the dust and gunk buildup. Lubricate the axle with oil, or I just spray with WD-40. Then reassemble.
The only thing I have had to replace is the on-off knob, since it's plastic and it split. Just get a universal knob from your local hardware store.
Lakewood HV-18... | Answered on Aug 22, 2012
Try McMaster Carr -- page 640, Fans and Fan Blades.
http://www.mcmaster.com/#ventilation-fans/=8qgdv5
Lakewood HV-18... | Answered on Sep 08, 2010
Dust is evil to all mechanisms!! Keeep UNPLUGGED..then Vacuum all accumulated lint in fan motor assembly, and soak with WD-40...I just did detailed dust cleaning with toothbrush....Fan now runs awesome!! Good Luck
Lakewood HV-18... | Answered on Sep 06, 2010
you have 3 control wires (the 3 speeds) and a common wire. the common wire will go directly from the fan motor to the power source/cord and the other 3 leads will run through the switch. you could even use a standard dimmer-style lighting rheostat and connect it to the common and "high" fan speed wire and have infinitely variable fan speeds. hope that helps.
Lakewood HV-18... | Answered on May 29, 2009
hello martin you can buy a dimmer to slow down your fan
800 watt at least
Lakewood Dryers | Answered on Apr 30, 2019
Lakewood HV-18 Floor / Box Fan Logo
17 questions posted
Top Lakewood Dryers Experts
Bruce Showalter
Craig Butler
Craig Butler
Steve Allison
Steve Allison
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
View Most Popular
Lakewood Dryers
  • Lakewood Dryers
Most Popular Question
clean lakewood fan mine filthy
  • Dryers
