20 Most Recent
Whirlpool MT1135SGB/Q Microwave Oven Questions & Answers
Where is the fuse for whirlpool microwave model number WMH31017HZ07.
The fuse for the Whirlpool microwave model WMH31017HZ07 is located inside the microwave oven. You will need to remove the outer cover of the microwave to access the fuse. Here are the steps to follow:
- Unplug the microwave from the power source.
- Remove the screws on the top of the microwave that hold the top grill in place. Remove the grill.
- Locate the screws that hold the control panel in place. Remove the screws and carefully pull the control panel forward.
- Locate the fuse holder on the right side of the control panel. Remove the fuse holder by pulling it out.
- Check the fuse to see if it is blown. If it is, replace it with a new fuse of the same type and rating.
- Reinstall the fuse holder, control panel, and top grill.
- Plug the microwave back in and test to see if the light is working.
If the light still does not turn on after replacing the fuse, there may be another issue with the microwave and it may require further troubleshooting or repair.
2/26/2023 10:32:17 AM •
Whirlpool...
Answered
on Feb 26, 2023
Whirlpool AKP 745 NB - just blink
It sounds like you are experiencing an issue with your Whirlpool AKP 745 NB oven. The fact that the oven is only blinking with an "auto" text suggests that there may be an issue with the electronic control panel.
A possible solution is to reset the oven by unplugging it from the power source for a few minutes, then plugging it back in. This can help to clear any temporary issues with the electronic control panel.
If the problem persists, you may want to check the user manual for any specific troubleshooting steps or contact the manufacturer for assistance.
Another possible solution to try is to reset the oven by pressing a certain combination of buttons on the control panel, as the manual suggests. If the problem still exists, it is advisable to contact the manufacturer or a professional technician for repair.
It's important to note that, electronic control issues can be caused by various problems, so it is best to refer to the user manual or contact the manufacturer for more specific troubleshooting steps and to get a more detailed diagnosis of the problem.
1/18/2023 6:51:14 AM •
Whirlpool...
Answered
on Jan 18, 2023
How do i get to the fuse on a Whirlpool microwave MH1170XSS
A bad fuse is one of the most common problems on microwaves, including Whirlpool ovens. Most modern microwaves use the same style of fuse which you can find at most appliance and electronics stores. The difficulty of replacing the fuse in a Whirlpool microwave can vary depending on whether you are working on a countertop microwave or a built-in. Knowing where to start can make the process much easier for either style of microwave.
Countertop Microwaves
Step 1
Unplug the microwave and let it sit for a few minutes before beginning repairs. Bring it to a clear area with enough room to work. Leave enough room to have access to it on all sides.
Step 2
Remove the Phillips screws from the outer shell of the microwave. The screws are located along the lower sides and around the edges of the back. Put the screws into a bucket or bowl to keep them together. Pull the shell away from the microwave, and set it to the side.
Step 3
Look for the fuse inside the exposed controls of the microwave. The fuse is located in a small receptacle with two wires running to it. Use a flat screwdriver to pry up from the bottom of the fuse. The fuse will pop out. Replace the fuse with a new one.
Built-in Microwaves
Step 1
Unplug the microwave, and let it sit for a few minutes before beginning repairs.
Step 2
Open the microwave door, and look for two Phillips screws along the left side of the control panel. Remove these screws. Lift up on the control panel, and tilt it outward. The control panel will rest on its hinges.
Step 3
Find the fuse receptacle within the control area. Is is usually located to the left or center of the cavity. You will see two wires that go to either end of a small, plastic receptacle. Use a flat screwdriver to pry up on the bottom of the fuse. The fuse will pop out. Replace the fuse with a new one.
1/16/2023 11:21:18 PM •
Whirlpool...
Answered
on Jan 16, 2023
Whirlpool Microwave time display
In today's fast paced society, time is of the essence. That is why many people rely on microwave ovens to help them prepare meals quickly. However, sometimes it can be difficult to determine how much time is left on a microwaved meal. Thankfully, most microwaves come with a time display that makes it easy to keep track of cooking time. In this article, we will take a closer look at the Whirlpool microwave time display and explain how to use it.
3/17/2022 4:51:48 AM •
Whirlpool...
Answered
on Mar 17, 2022
