20 Most Recent
Kenmore 30" Microhood Combination, Stainless Steel Questions & Answers
How high should the microwave be above the stove?
In our area the bottom of the cabinet that you are mounting it to needs to be a minimum of 66" from the floor. You should check around with someone in your area to see what local codes are for mounting your microwave. Most of the time this will put the bottom of your microwave anywhere from 16" to 20" above your stove. See the following link for a listing of many types of appliances and their clearance needs.
Kenmore Elite 790.99913804 gives an E0 39 error when trying to use the cooktop.
The E0 39 error on a Kenmore Elite 790.99913804 cooktop indicates a communication error between the user interface board and the power supply control board. This error can occur due to a faulty connection or damaged wiring between the two boards.
If replacing both the user interface board and power supply control boards did not resolve the issue, it is possible that there is a problem with the wiring harness or another component in the cooktop. It may be necessary to consult a professional technician to diagnose and repair the issue.
In addition, it is recommended to check the user manual for troubleshooting steps specific to this model of cooktop. The manual may provide additional information on how to resolve this error code.
Kenmore Elite 790.9505 Range
The Kenmore Elite 790.9505 range is a kitchen appliance designed for cooking and baking. It features a variety of burners, including a powerful 18,000 BTU Turbo Boil burner and a simmer burner for delicate foods. The oven has a large capacity and offers convection cooking for even baking and roasting. The range also includes a number of convenient features, such as a self-cleaning oven, electronic controls, and a built-in timer. Overall, the Kenmore Elite 790.9505 range is a versatile and high-performing appliance that can help make cooking and baking easier and more efficient.
What's the gas oven ignitor part number for a Kenmore Elite 790.3670?
The gas oven ignitor part number for a Kenmore Elite 790.3670 may vary depending on the specific model and serial number of your appliance. However, a commonly used gas oven ignitor for this model is part number 5303935066.
I would recommend checking your owner's manual or contacting Kenmore customer service to confirm the correct part number for your specific appliance. Additionally, it's important to ensure that you purchase a gas oven ignitor that is compatible with your Kenmore Elite model to avoid any potential issues or safety hazards.
Problem with kenmore elite gas range. Oven will not heat
It sounds like you may have a problem with the gas valve or the igniter in your Kenmore Elite gas range. The gas valve controls the flow of gas to the burner, and the igniter provides the spark to light the gas.
If the glow plug is coming on but the gas is not igniting, it could be a problem with the igniter itself or the gas valve. The igniter may not be producing a strong enough spark to light the gas, or the gas valve may be clogged or malfunctioning, preventing the gas from flowing properly.
You may want to have a professional technician take a look at your range to diagnose and fix the problem. It is important to have any gas appliance serviced by a qualified technician to ensure safe operation.
Kenmore gas range slow to preheat, takes 1 hour to get to temp.
There are several potential causes for a gas range being slow to preheat. Here are some troubleshooting steps you can try:
- Check the igniter: While the igniter may be coming on, it may not be getting hot enough to ignite the gas. Make sure the igniter is clean and free from any debris or corrosion. If it is dirty, gently clean it with a soft cloth. If the igniter is damaged or not getting hot enough, it may need to be replaced.
- Check the gas supply: Make sure that the gas supply is turned on and that the gas pressure is sufficient. If the gas pressure is too low, the oven may take longer to preheat.
- Check the oven temperature sensor: A faulty temperature sensor can cause the oven to take longer to preheat. Use a multimeter to test the sensor for continuity. If it is not working properly, it may need to be replaced.
- Check the oven door seal: A faulty oven door seal can cause heat to escape, making it difficult for the oven to reach the desired temperature. Inspect the seal for any cracks or gaps, and replace it if necessary.
- Check the oven igniter safety valve: The igniter safety valve is responsible for regulating the flow of gas to the oven. If it is faulty, it may be restricting the flow of gas, causing the oven to take longer to preheat.
If you are uncomfortable performing any of these troubleshooting steps yourself, it is best to contact a qualified appliance repair technician for assistance.
30" Kenmore gas range door is locked and can not be opened.
If your Kenmore gas range door is locked and cannot be opened, try the following steps:
- Check the control panel for any error messages or fault codes. If there are any, try to clear them by unplugging the range for a few minutes and plugging it back in.
- Check if the oven is in self-cleaning mode. If it is, the door will automatically lock and will not open until the self-cleaning cycle is complete. Wait for the cycle to finish and the oven to cool down before attempting to open the door.
- Try resetting the door latch. Turn off the power to the range for at least 30 seconds, then turn it back on. Press and hold the "Clear/Off" button for three seconds. This should reset the door latch and allow you to open the door.
- If none of the above steps work, it's possible that the door latch or locking mechanism is malfunctioning and needs to be replaced. In this case, it's best to contact a qualified technician to diagnose and repair the issue.
Why does one burner on a Kenmore 790.72903013 always spark, no matter which burner I turn on?
If one burner on your Kenmore 790.72903013 range is always sparking, regardless of which burner you turn on, there are several possible causes:
- Burner switch: The burner switch controls the flow of electricity to the burner. If it is faulty, it may be sending electrical current to the wrong burner, causing it to spark.
- Wiring: Damaged or loose wiring can also cause a burner to spark.
- Control module: The control module is the electronic component that controls the burner. If it is malfunctioning, it can cause the burner to spark.
- Surface burner receptacle: The burner receptacle is the part of the range where the burner plugs into. If it is corroded, it can cause the burner to spark.
- Burner itself: If the burner itself is malfunctioning, it can cause it to spark.
It is important to unplug the range from the power source before attempting to diagnose or repair the issue. If you are unsure about how to troubleshoot and fix the problem, it's best to call a professional technician or the manufacturer for assistance.
WHAT ARE THE DIMENSIONS ON KENMORE STOVE 317B6034
I am unable to locate specifications of this stove. At best, I can merely suggest you have that model number at hand whille you call the Sears customer service number:
Customer service
+1-800-366-7278
M-F
8:30 am-7:30 pm
Central
Sat
8:30 am-7:30 pm
Central
Sun
9:30 am-7:00 pm
Central
