SOURCE: kenmore 78618 gas range
Yes, the orifice will is in the center of each burner and will unscrew. Make sure new orifices get installed in the correct burner or it won't work properly. I think you will use a 6mm nut driver to unscrew the orifices. Can use a ratchet and socket also.
SOURCE: Need to replace drop in range
All you have to do is make sure you have the same drop in top as the hole cut for it. Measure the opening, and then measeure flange to flange on the one you have. The flange will be 1/2" or so bigger than the hole; that's what holds it in.
They are ususall 30 or 36" wide. It doesn't have to be a Kenmore, just match the color to everything else.
Need to know how to disconnect it?
Dan
SOURCE: Kenmore Elite Range door locked error message
Hold down the number three button until the LOC message disappears and then the door will open.
Manuals available here:
http://www.managemylife.com/mmh/owner_manuals/search?sid=MMHMxSearsx00019&query=FGF316DSD+FRIGIDAIRE
