20 Most Recent
Sterling 60"L x 42"W Almond Tub 71111110-47 Questions & Answers
How duo I change the time on my Sterling & Noble wall clock? It does not have any dials on the back to turn?.
To change the time on a Sterling & Noble wall clock that does not have any dials on the back, you will need to follow these steps:
- Locate the small, round hole on the back of the clock. This is the reset button.
- Using a small object, such as a paperclip or a toothpick, press and hold the reset button for about 5 seconds. This will reset the clock and allow you to set the time.
- Release the reset button, and the minute hand will begin to move around the clock face. Use the reset button to advance the minute hand to the correct time.
- Once the minute hand is set to the correct time, the hour hand will begin to move around the clock face. Use the reset button to advance the hour hand to the correct time.
- Once the hour hand is set to the correct time, the clock will begin to run normally.
I hope this helps! If you have any further questions, don't hesitate to ask.
Sterling & Noble wall clock minute hand has fallen off. How can I put it back on?
Unless the clock is an older traditional 'clockwork' mechanism most clocks have a sealed unit as a mechanism so you shouldn't damage anything.
Some clocks can be dismantled from the back, usually with small screws or spring clips. You remove the clock face and mechanism as One piece. Once removed, the hands are usually a push fit so should pull out. The Second hand, then minute hand and the hour hand nearest the clock face.
If you need to replace the mechanism they are held on with a small nut on the face of the clock. These mechanisms are usually quite cheap to buy and easy to fit.
