20 Most Recent
Harman Kardon AVR 5 Receiver Questions & Answers
Harmon Kardon AVR 5
Assuming that the system is properly installed and was working ok before, the problem is usually a blown output amplifier in one channel and the receiver disconnects the speakers to avoid damaging them. In this case, professional repair is required.
Volume display seems backward
This is because the volume knob on ANY stereo is actually an attenuator. Meaning, the stereo would play at full blast (way too loud!) if left to it's own limits of power, so your volume knob is actually "dialing down" the power, or when fully turned up, letting it all flow.
The reason that the numbers change like that is it's showing you how much attenuation is happening in decibels, or dB, so for insTance, when it's at "-30" that's a pretty decent volume, but at "-5" it's much louder and your neighbors might complain. I think you'll notice that it can be cranked to something like "+5" which on my AVR 100 will blow the speakers.
In other words, this is normal, so relax and enjoy the music!
Receiver power problem
If you smell something burning its about 99.9% sure that there's permanent damage to the power supply and unless you know how to troubleshoot electronic curcuits it would be best to take to a pro or contact HK at
[email protected] good luck
Harman Kardon AVR 630 8CH mode not available
According to the Harman-Kardon AVR 630 User Manual, if the 8CH mode is not available, you can try unplugging the unit from the AC wall outlet and waiting for at least three minutes. After the pause, reconnect the AC power cord and check the unit's operation. If the system still malfunctions, a system reset may clear the problem. The 8CH may not be available according to the user manual. You need to contact Harman-Kardon customer support.
Harman kardon avr 146 no front led display. but clicks on from orange light to blue. is there a fuse for display screen ? fuse at AC in is OK.
Hello, there is no fuse for the screen, there is a power supply circuit that makes it work and that if it is wrong the screen does not work
The rest of the team works well? Can you hear something?
if not, you do not have a display problem, you have a bigger problem
If you have knowledge to review it, I will attach the service manual, but go to a specialized technical service
Hola, no hay fusible para la pantalla, hay un circuito de fuente de alimentaci?n que lo hace funcionar y que si esta mal la pantalla no funciona
El resto del equipo funciona bien?, puedes escuchar algo?
si no, no tienes un problema de display, tienes un problema mayor
si tienes conocimientos como para revisarlo, te adjunto el service manual, sino dir?gete a un servicio t?cnico especializado
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Harman-Kardon-AVR-146-Service-Manual.pdf
