Question about Harman Kardon Audio Players & Recorders
Harman kardon avr 510 reset - Harman Kardon Audio Players & Recorders
Posted by Lisa White on
ADMIN Canada
    Top Expert:
  • Harman Kardon Master
  • 41,560 Answers
Page 53 of the manual
Troubleshooting Guide; Processor Reset - Harman Kardon ...
https://www.manualslib.com > ... > Owner's manual
Harman Kardon AVR 510 Manual Online: troubleshooting guide, Processor Reset. Symptom Unit Does Not Function When Main Power Switch Is Pushed ...
Posted on Jun 04, 2021
5 Related Answers
Anonymous
  • 44 Answers
SOURCE: Harman Kardon avr 1500 service manual
try here - http://www.harmankardon.com/product_support/support_detail.aspx?prod=AVR500
Posted on Dec 16, 2007
Anonymous
  • 1512 Answers
SOURCE: How to I reset my
Hi odysy
I got this from the manual page 43.
Resetting the Remote Memory
As you add components to your home-theater
system, occasionally you may wish to totally
reprogram the remote control without the confusion
of any commands, macros or ”Punch-
Through“ programming that you may have done.
To do this, it is possible to reset the remote to the
original factory defaults and command codes by
following these steps. Note, however, that once
the remote is reset, all commands or codes that
you have entered will be erased and will need to
be re-entered:
1. Press any of the Input Selector buttons 4
and the ”O“ button Hat the same time until
the Program/SPL Indicator 2begins to flash
amber.
2. Press the ”3“ button Hthree times.
3. The red LED under the Input Selector4
will go out and the Program/SPL Indicator
2will stop flashing and turn green.
4. The Program/SPL Indicator 2will remain
green until the remote is reset. Note that this may
take a while, depending on how many commands
are in the memory and need to be erased.
5. When the Program/SPL Indicator 2goes
out, the remote has been reset to the factory settings.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards robotek
Posted on Jun 29, 2008
Anonymous
  • 13 Answers
SOURCE: Harman Kardon AVR 135 6.1....AUDIO DELAY???
This model does have a delay function. Programming is on page 19 of the user manual. Go to http://www.harmankardon.com/product_support/interstitial.aspx?sJump=ps&Region=USA&Country=US&Language=ENG select all products, AVR135, and get the owner's guide. If you have trouble with the link, then go to the Harmon Kardon site, and make your way to the support portal and then select all products.
Posted on Nov 26, 2008
Anonymous
  • 382 Answers
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Posted on Jan 01, 2010
Testimonial: "cheers, have a good year."
Anonymous
SOURCE: My Harman Kardon AVR 330 is locked. Can't unlock
youtube
myspace
facebook
Posted on Feb 12, 2010
1helpful
I have harman kardon AVR 7000 the power light come on but the front display is not light up how can i try to reset the unit
You can go online and find manual took about 7 seconds.
Hint page 46
Bigger hint
https://www.manualslib.com/manual/65710/Harman-Kardon-Avr-7000.html?page=46#manual
Harman kardon avr 3600 no signal after firmware update..i think the firmware only got partial install
Try resetting the processor follow the link this will tell you how to do it.
https://www.manualslib.com/manual/278933/Harman-Kardon-Avr-300.html?page=38
2answers
HOW TO RESET HARMAN KARDON AVR70
Hi, Try this. Hope this helps and I have the link here to the manual.
Processor Reset
If the AVr behaves erratically after a power surge, first turn off the front-panel
main
power switch and unplug the Ac power cord for at least 3 minutes. plug the cord back
in and turn the AVr on. If this procedure doesn't help, reset the AVr's processor as
described below.
note: resetting the processor will erase all user configurations, including speaker and
level settings, and tuner presets. After a reset, reenter all of these settings from your
notes in the Appendix worksheets.
To reset the AVR's processor:
1. press the front-panel Standby/on switch to place the unit in the Standby mode (the
Standby Indicator led will turn amber).
2. press and hold the front-panel Standby and memory/folder buttons until the reSet
message appears on the front-panel message display.
3. press the memory/folder button again to reset the AVr's processor.
If the AVr does not function correctly after a processor reset, contact an authorized
harman
kardon service center for assistance.
to locate an authorized service center,
visit our web site at www.harmankardon.com.
https://www.harmanaudio.com/on/demandware.static/-/Sites-masterCatalog_Harman/default/dw409ee4c9/pdfs/AVR700NEW_OM_EN.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/laura_08254539050d64db
How do i reset an harman kardon avr-310
There is no reset for it, If it doesn,t stay on something is wrong with it,End it has to be taken in for repair,
Top Harman Kardon Audio Players & Recorders Experts
 Francisco Mauricio...
 Grubhead
Grubhead
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
