20 Most Recent
Nikon Coolpix S6200 Digital Camera Red 16gb Sd Card Kit Questions & Answers
Why are my pictures are blurred and have a pinkish hue
I don't know why. But if I had the camera in my hands I would check the settings. If the camera was in Automatic In the menu settings. Also how the White balance was set. It also should be in automatic.
It is great to try to achieve better pictures, by changing the settings, but the best thing to learn is to switch all settings back to automatic, when ready. So the next time you use the camera you won't get surprises.
If the quality of the pictures does not become better after you switched to automatic, you should contact a Nikon certified repair centre close to you.
Just bought Nikon p600 and cant connect to WiFi help
U need to download nikon wmu software from google playstore or appstore. Then start wifi of ur camera and then start wifi connection in ur mobile.select "nikon p600" in wifi setup.when connected, start application named "wmu" in ur mobile.wait for the connection.after few seconds wifi connection will be established.hope this would help u!
My Nikon b500 Coolpix won't turn on just flashes green
It flashes green when it is basically on but in a sub mode that I'll call CHARGE MODE. If it is flashing that means the battery is charging. I suggest to let it continue to charge until it stops flashing and then remove the charger connection. When the camera is sitting all by itself with nothing connected you can then turn it on.
The screen on my Coolpix 500 looks like a chemical was poured on it. It is not scratched, what can I do
Is it the screen, or the screen protector ? If the latter, just remove it and replace it. If it is the actual screen, first of all try a lint-free cloth barely dampened with distilled water, and test it on a corner, see if that works. On no account get the camera wet. If that is unsuccessful, try adding a very little diluted washing-up liquid, and try again. Should that not succeed, I would advise taking the camera to your local repair facility for their expert advice.
