20 Most Recent
True GDM-26 Refrigerator Questions & Answers
Where is ballast
Open the ventilation slats at the bottom should be two screws on each side. Then in the center is another cover remove that the balance should be inside. Another clue would be the box with the plug on the side of it is the compressor plug that's the box I am referring to.
Wiring diagram
Should be under the wiring cover behind the vent slats.
Gdm-26 does not get cold, makes a clicking noise
Replace the thermal/starter relay. It is located on the side of the compressor. It clicks like if you unplugged the unit and plugged it back in quickly causing an over load on the compressor due to the high side still having high pressure and have to wait for a couple of minutes before you plug it in. The relay is at fault. Hope This Helps.
