Most CD's and Dvd's don't need drivers, they are universal standard equipment. If your DvD Drive is not working then click Start/My Computer and check to see if your drive is listed as a device. If not, Remove the Power Cord, Remove the Case, Remove the two cables that go into the DvD Drive, then put them back. Reboot and see if your drive is listed now.If not, you will need to remove Upper and Lower Filters.Windows 7To resolve this problem on a computer that is runningWindows 7, use the Hardware and Devices troubleshooter. For more informationabout how to open this troubleshooter in Windows 7, visit the followingMicrosoft Web site:
http://windows.microsoft.com/en-us/windows7/Open-the-Hardware-and-Devices-troubleshooterBack to the topWindows Vista
- Click Start
, and then click
All Programs.
- Click Accessories, and then click Run.
- Type regedit, and then click OK.
If you are prompted for an administrator password or for aconfirmation, type the password, or click
Allow.
- In the navigation pane, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
- In the right pane, click UpperFilters. Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
- On the Edit menu, click Delete.
- When you are prompted to confirm the deletion, click Yes.
- In the right pane, click LowerFilters. Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
- Exit Registry Editor.
- Restart the computer.
Now go to the
"Did this fix theproblem?" section.
Back to the topWindows XP
- Click Start, and then click Run.
- In the Open box, type regedit, and then click OK.
- In the right pane, click UpperFilters. Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
